new CK3510HST Tier 4
   / new CK3510HST Tier 4 #1
rkroeker
Hartsel, Colorado
Kioti CK3510HST
From what I'm reading limit idling the tractor, question is how to break in the tractor...baby it, run it hard. I don't know much about DPF, just want to learn more so I understand it and how to avoid problems. Also seems like people having issues with cold climate (winter time) maybe block radiator to build heat. any advise would be great.
Thx Robert
   / new CK3510HST Tier 4 #2
Break-in, just be nice. Some folks on here just run the machine like they always would from day one. If you happen to be learning, just take it easy anyway. As far as idling, I read on here to bump it to 1500 RPM for warm ups and most idling, the engine runs smoother and shakes less. I wouldn't worry about idling too long, just don't leave it running all night since it's already going :laughing:
on the DPF, I found the tractor automatically ran a regeneration cycle in the first 30 hours for me, I have since used cardboard to block my radiator in the winter months because the engine would not get up to temp. If you are putting load on the engine in cold weather and it isn't up to temperature, it will start blowing black smoke (fuel), and this will clog the DPF faster. The regeneration cycle essentially heats the exhaust filter up and burns out the soot. I imagine this has to be done more often if you are running the engine cold and making smoke.
Thx for the info, I can't wait to get it, they will deliver it Friday.
   / new CK3510HST Tier 4 #4
No problem, I wish this info was a little more prevalent. The manual helps, sort of.
You will like your new Kioti, they are a great value.
2012 CHEVROLET EXPRESS VAN (INOPERABLE) (A52472)
2012 CHEVROLET...
(10) 2 PLUG VALVES (A52472)
(10) 2 PLUG VALVES...
2013 WESTERN CONSTRUCTION COMPONENTS BELLY DUMP TRAILER (A52472)
2013 WESTERN...
2011 Manac 36245B30 43ft T/A Walking Floor Trailer (A50322)
2011 Manac...
48" Pallet Forks  (A52384)
48" Pallet Forks...
