Snow new ck30 HST first problem
   / new ck30 HST first problem #1
haroldy
near peterborough,ontario
kioti ck30,,front mount snowblower
When snow blowing with front mounted blower sometimes have trouble steering when blower catches snow bank on the edge of the road . With my old geared tractor I would touch the left or right brake to correct direction, however with the HST this disconnects the cruise control ,,I haven't had a chance to see if I can modify yet
any suggestions would be welcome
   / new ck30 HST first problem #2
I wouldn't call that a problem....it's doing what it's supposed to do. Modifying it could cause problems for the transmission, and almost certainly void the warranty. I certainly wouldn't want to be dragging a brake while the transmission is under load....slipping clutches, overheating fluids, etc.
Did your geared tractor have electronic cruise control?
No, you are right it isn't a problem , but it is inconvenient . the geared tractor just worked better in this situation. The cruise control on the CK30 is a mechanical cruise
   / new ck30 HST first problem #4
Don't use the cruise control when plowing.
New/Unused CFG Industrial MX15RX Mini Excavator (A57453)
New/Unused CFG...
2013 Chevrolet Silverado 4x4 Service Truck, VIN # 1GC2KZCGXDZ156404 (A57453)
2013 Chevrolet...
2001 PETERBILT 379 (A58214)
2001 PETERBILT 379...
2016 VOLVO VNM SINGLE AXLE DAY CAB (A59575)
2016 VOLVO VNM...
2002 Ford F-550 Dump Truck, VIN # 1FDAF56F32EC86522 (A57453)
2002 Ford F-550...
New/Unused SD Lanch SDLE20 Mini Excavator (A57453)
New/Unused SD...
