New CK20STD Owner with Questions
   / New CK20STD Owner with Questions #11
</font><font color="blue" class="small">( Oh yes...I recall reading about those first steam engines. )</font>
Now THAT was just low, or as Jack Benny (not someone you'd know) used to say...
NOW CUT THAT OUT!
John
   / New CK20STD Owner with Questions #12
NOW CUT THAT OUT!
John
Thank you KiotiJohn and CBB for the good, common sense advice.
I can hardly wait for this weekend to use the Kioti to mow and move rocks and fallen trees. Hopefully the rain will stay away from New Hampshire!
I was wondering why I got the tractor so cheap -- it has an STD!!!
   / New CK20STD Owner with Questions #15
</font><font color="blue" class="small">( I was wondering why I got the tractor so cheap -- it has an STD!!!)</font>
To avoid embarrassment you may wish to use its official title of CK20J
Good tractoring. I know you're going to have great fun.
John
   / New CK20STD Owner with Questions #16
John
   / New CK20STD Owner with Questions #17
One of my first jobs to break in my CK30 was mowing a 6 acre bumpy field that took 10 hours. I was sure to adjust the rpms between PTO540 and about 2000 as I went along. The field was tall but the tractor wasn't lugged since I was going so slow due to terrain.
Check the radiator screens often, they will accumulate junk and lead to overheating.
Driving on the road is a 2wd job. Also, go kinda slow since the bumps in a road will bounce a suspensionless tractor pretty good. Flashers, seatbelt, etc. are good.
I have actually noticed pretty substantial front tire wear on my tractor after the first 200 hours. I do not run on any asphalt but use 4wd most of the time and my dealer thinks the scrubbing is wearing them out. He and I both measured the toe in and it is within specs. It's not enough to need replacement but noticeable. The big rears still look new.
Put the tractor to work and enjoy the nice swish sound of the blades cutting through grass. Check oil and note that your fuel gauge will stay full and then all of the sudden go down quickly to empty.
   / New CK20STD Owner with Questions #18
   / New CK20STD Owner with Questions #19
</font><font color="blue" class="small">( note that your fuel gauge will stay full and then all of the sudden go down quickly to empty. )</font>
I think that might be a CK30 issue only. My 20's fuel gauge seems to work just fine.
Jim
   / New CK20STD Owner with Questions #20
Jim
(APPROX. 20) 4' X 8' X 3/8" SHEETING (A52706)
(APPROX. 20) 4' X...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
2019 International Bucket Truck (A55973)
2019 International...
2014 Ford F-150 4x4 Crew Cab Pickup Truck (A55973)
2014 Ford F-150...
2017 Ford F-450 Service Truck w/ Liftgate (A56858)
2017 Ford F-450...
2010 LAREDO 5TH WHEEL (A55745)
2010 LAREDO 5TH...
