Flail Mower New Caroni TM1900 Flail Mower
   / New Caroni TM1900 Flail Mower #23
Bad news.
The 3038e has an electrically operated PTO system that has an internal braking system. It's either on (spinning) or it's off (locked). The dealer recommended adding an overrunning clutch to the PTO shaft of the tractor so that you can spin it one way by hand to line it up.
I think I'll try getting a PTO extension and welding a handle to it so that I can force it to spin by hand first. It won't take much to line up the splines.
JD let me down on this one.
Good Morning nunya
My 3520 has an electrically operated PTO as well. It does not need an over riding clutch and run the Caroni flail mower with ease.
As to the PTO mounting problem...Does your tractor have the mid PTO? If so shift it to he mid position and you will be able to rotate the tractor shaft easily.
   / New Caroni TM1900 Flail Mower #24
Jer,
Thanks! That's what i had heard, too. Had no idea the Caroni was that reasonably priced.
How do you adjust height?
Can you adjust height on the fly via 3pt adjust or a hydraulic adjust?
Is there a 7' available that will work with 38PTO HP?
Hi,
Height can be adjusted with the 3pt, but the best way is to adjust the rear roller and outer 'skids'. That way you just 'drop' the mower to the preset height and go. If you need to lift it to get over a rock or other obstacle, you can simply pull up on the 3pt lever and drop it again once your past.
There are hydraulic offset kits, which look pretty cool, but I didn't deem necessary. They'd be really nice to getting in corners and around trees.
There are 7' available, but not by Caroni. The Caroni's are pretty special in terms of pricing. A 38hp machine might run a 7', but I'd ask around first. I think a 6' would be fine for your machine to run.
Check eBay. I looked the other night and there were some good options. The flails are such a simple design that even if it looks rough around the edges, it'll still likely work for you.
-Jer.
   / New Caroni TM1900 Flail Mower #25
I tried a Caroni flail mower a few years back and did not like the finish it left my lawn with. Turned out to be the cutters on it and for that model were "Y" shaped and my lawn looked like narrow rows of grass up and down in height. Looked sort of neat looking across the cut but down the cut looked tacky. Did like the cutter very well. The other issue I did not like was the rear roller needed to be lifted for turning sharp turns. But the Caroni carries a good reputation. Think the reason the price jumper with Agri Supply on this was the "Dollar's" value drop. Right sure at least part of the price jump was due to that.
   / New Caroni TM1900 Flail Mower #26
Actually, the dollar has strenghtened in the past year, which helps explain the price increase. Since the flail is made in Italy, as the dollar increases vs the Euro, the same number of dollars = fewer Euros which means Caroni needs to increase the price in dollars to get the same number of Euros it was getting when the dollar was cheaper.
Anyway, following this thread for future reference. Maybe some day I'll have both the need for and tractor required to run one of these flails. Before reading up on the flails, I would have opted for a bush hog style cutter without thinking. The flails sound much more practical with the possible exception of cost.
   / New Caroni TM1900 Flail Mower #27
Hi,
-Jer.
So you've seen them have hydraulic height adjust or is it a hydraulic angle adjust?
Is it available on the caroni?
Caroni has a hydraulic side to side adjuster available. Adjusts how far the unit sticks out the right side of your tractor on the fly.
You can use a hydraulic top link to make fine adjustments in cutter height. Lengthen the top link to raise the cut and shorten the top link to lower the cut.
   / New Caroni TM1900 Flail Mower #29
I do like how versatile the flail mower is and how much lighter they are than a rough cut mower. For such as cutting ditches or as a boom mower I think they are tops. Just realize some are more designed for rough cut and others for finish cut and I guess some for both due to the differences in cutters or hammers they have for that model.
   / New Caroni TM1900 Flail Mower #30
Glad you are enjoying your mower! I am considering one for our horse pastures, but its not clear to me how adjutable they are. I like to cut the pasture to about 5 inches. Ground is pretty level. Is it possible to do this by adjusting the roller or would I simply lift the entire moer via 3pt hitch? If by the hitch is the unit really heavy? Also does roller interfere on turns, have sort of alot of corners.
Year: 2017 Make: Dodge Model: Grand Caravan Vehicle Type: Van Mileage: Plate: Body Type: 4 Door V... (A55758)
Year: 2017 Make...
SINGER 211 UPHOLSTERY SEWING MACHINE (A54757)
SINGER 211...
GODWIN 6 HEAD PUMP (A55745)
GODWIN 6 HEAD PUMP...
SHOP TABLE (A55745)
SHOP TABLE (A55745)
AUTO REWIND 12V HOSE REEL (A54757)
AUTO REWIND 12V...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
