New BX Model Announced
/ New BX Model Announced #1
66gladiator
York South Carolina
Various
Kubota announced a new BX2650 model late Friday available 4th quarter of 2007.
The new tractor has all of the features of the BX2350 but with two major and other enhancements:
  • Best-In-Class Horsepower: 25.5HP in a 3 cylinder 1001cc diesel.
Radiator size increased 20% over BX2350.
Overall weight increased only 68lbs; most incremental horspower will be usable.
  • Best-in-Class Operator Seating Comfort: New deluxe, high-back recling seat with retractable seat belts. This seat also has thigh support and padding.
I scanned a pic, but it is grainy.
/ New BX Model Announced #2
How will that effect the BX24? What other enhancments? I'm about ready to pull the trigger on a JD2305 or JD2320. One of the reasons for the 2305 is I can get a factory hoe later, I don't have to buy now.
/ New BX Model Announced #3
My understanding is that the BX24 will stay since the sales are so good. This is just a BX lineup addition.
/ New BX Model Announced #4
What type of 3 point position controle does it have?
Hagman
B7610 w/ MMM, Box Blade, FEL & Trac Vac
/ New BX Model Announced #5
Any info on loader specs or 3 point specs?
KC
The only changes are Horsepower/radiator and the seat, everything else including implements are the same as the BX2350.
/ New BX Model Announced #7
Im sure the price will change as well:D
KC
/ New BX Model Announced #8
??? Does anyone think the BX2200/2230/2350/23/24 is hurting for horsepower? Why make an adjustment like this (add 4 HP) without having an adjustment to SOMETHING that is useful to the user?
Some suggestions, if I may:
--Larger pump (more volume available for multi-function use of BH? Higher ground speed?)
--Higher capacity FEL?
--Longer wheelbase or wider stance? The BX could use more stability, not more power.
I guess it would be OK if they fitted it with a 72" wide MMM or something. But I guess the Tim Allen's of the world will pay what they're asking for "the biggest" without pondering how well the machine works with the "lesser" motor. Ask anyone with a BX1500 if THEY feel short on power (fully conceding the smaller chassis/wheels presents some limitations). I can tell you that I have power to spare. Never wanted more.
/ New BX Model Announced #9
The ROPS looks shorter than on my BX24. Is this how all the BX's that don't come with a backhoe are, or did they shorten it for this model? I wish mine were about 3" shorter, since I've driven into my garage door frame twice in my 4.5 weeks of BX24 ownership. :rolleyes: I figure I'll drive into it one more time before I remember for good.
/ New BX Model Announced #10
Got a better one for ya... why is "Best in Class HP" braggin' rights anyway? Wouldn't "Best in Class Torque" be a more respectable achievement? Heck, maybe it has but we'll never know since Kubota doesn't publish torque figures :eek:. Which never fails to astonish me, since we're talking about Diesel engines after all. Torque is everything, HP is consequential. As long as the general public continues to blindly and ignorantly buy into HP figures (which as we know are ONE point on the curve, typically at some impractically-high rpm), we'll continue to see this kind of "HP Wars" driven marketing propaganda again & again, whether its wheel loaders or weed wackers.
Keep the meaningless discrete data points and show me real torque dyno graphs, and maybe HP curves if you got room on the printout... then maybe I can be impressed.
/ New BX Model Announced #11
I agree, I don't see the point of a simple HP increase in the sub class. I would think 23 HP would be more than adequate, especially without more weight to help get it to the ground.
/ New BX Model Announced #12
Keith: I've always appreciated your POV and your helpful comments. Please understand that my disagreements here are just a matter of opinion based on how I would use the tractor differently in my own situation.
Actually, yes. I would like to be able to apply more HP to a generator and a chipper/shredder without going to a larger/heavier tractor.
I agree with the larger pump. My durapan (ultrahard hardpan) is probably not bh diggable with the BX pressure. More pressure to a BH might make it possible to rip through it. Three HST ranges would be nice for a LOWER gear range in that I could apply more torque when pulling a sub-soiler in my hard clay topsoil and the claypan that is between the clay and the durapan.
I think the current capacity, when full of clay or rocks, already throws the balance off, even with a counterweight.
Personally, if I wanted a slightly longer/wider wheelbase, I think that already exists in the B series. I need to keep the tractor small for manuvering in small spaces, but could use the extra hp in the ways listed above. I also want to keep it small and light so that I don't have to go to a larger trailer and tow vehicle.
I would like to see a similar BX26 (same new engine) with backhoe. (Can this be far behind?) Optional things I'd recommend adding beyond the BX24 are: thumb that comes welded in place, bh rip shank like the Bro-Tek, hydraulic cutter attachment for end of BH arm (to cut roots), grapple for FEL, 4 way FEL bucket. An optional removable cab and air conditioner would be a dream for the times when I'm brush hogging in 115 degree heat and the pulverized material is as thick as a dust storm.
If others would add to this list below, things they would like to see added to or upgraded on this same tractor, just possibly Kubota might consider some of the suggestions. What would the ideal BX be like?
/ New BX Model Announced #13
DiezNutz said:
"Best in Class Torque" be a more respectable achievement?Torque is everything, HP is consequential.
Yes, yes, and yes. Torque is king in this application, no doubt. Thank you for clarifying. Blindly assumed the weren't trading Torque for HP, but it would be nice (and telling) to provide the power/torque curve so we can assess it for ourselves.
The best engine in the world (IMHO) is an 8-cylinder 16-valve pushrod wonder-brick in a cute little car called the Corvette. Others can easily extract 400 HP out of a 2 liter engine at 17,000 rpm, but without torque, it can't push much more than a motorcycle. Honda S2000. Mazda RX-7/8. Mitsu Evo. All amazing cars that make zero torque when not at 7,000 rpm (and little torque even then). But a small illustration of your point.
That comment means a great deal to me. Thank you.
I guess in the context of your thoughts, when does the BX become a little B? I mean, how much more could it do before it "outgrows" its frame? Not much more FEL, I agree. Larger chipper, sure...but even with 26 HP and this machine chomping at 3 inch limbs, the thought would be "what about 32 HP so I can do 4 inch limbs". At some point, one needs to consider a larger tractor since you can't lug around the chipper that the ENGINE is capable of running because the FRAME/3PH is too small.
I agree with the "larger wheelbase" thought. Just cultivating possible directions for the BX line. Looks like it is getting larger tires unless I'm not looking at the picture right. They look bigger anyway. Dunno.
To have a bump in engine size without a larger hydraulic pump would be pointless. Full concurrence on that point. That, a larger deck and a little more tire? What else could you do before you flirt with a B7610 that is short on size and capacity?
But who really cares. They've done a great job with the BX line. Some could call it their bread and butter, in some regards. To offer it with more HP wouldn't offend me one little bit. It'd just be nice for them to throw some chili power in the gravy to give it a little kick.
/ New BX Model Announced #14
The larger engine should tell you that you should have more torque. Now, to have a wider deck would require a longer wheel base with larger tires and that is where the larger B-series comes in! Unless someone could build a four blade mower to shorten the front to rear distance of the deck.
/ New BX Model Announced #15
Why not 5 blades. Have them counter-rotating and embedded like a Chinnook. That'd get rid of those pesky blades of grass that sneak through a normal 3 blade arrangement in a turn.
Gillette does it, why can't we? DREAM BIG, GUYS!!! I want a MACH 2 tip-speed on those suckers. A billion miniature sonic booms a minute. YEAH!!!
/ New BX Model Announced #16
I couldn't quite tell, but I wondered whether the wheel rim is a larger diameter, the sidewalls narrower, and the outer tire diameter unchanged. I'm seeing a lot of cars now with those very narrow sidewalls. They say that within 20 years, the wheel/rim will have so much flex and ability to absorb shock that tires will no longer be pneumatic. The rubber will be applied straight to the steel with no air involved.
/ New BX Model Announced #17
Great, even tractors aren't safe... next model that comes out will be sittin' on dubs with spinners.
/ New BX Model Announced #18
Did you eat too many paint chips as a kid? :D
2015 Bandit 200UC Chipper (A63689)
2015 Bandit 200UC...
24" BUCKET (A64277)
24" BUCKET (A64277)
Caterpillar C18 Industrial Diesel Engine - Serial N8F01121 - Power Unit - Pump Takeout (A63689)
Caterpillar C18...
2016 KENWORTH T680 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2016 KENWORTH T680...
NEW IDEA 323 - 1R CORN PICKER (A64277)
NEW IDEA 323 - 1R...
(1) 40 Yard Roll Off Dumpster and (1) 30 Yard Roll Off Dumpster (A65579)
(1) 40 Yard Roll...
