New buyer, there is a lot to consider, need help
   / New buyer, there is a lot to consider, need help #11
Additional info:
New Holland Superior Operator Comfort
Benefits
•Deluxe cushioned seat
•Seat adjustment on incline/decline plane for optimum
visibility and access to controls.
•Weight control and swivel adjustment on seat
•Arm rests available
Value
•Better vision results in safer operation
•Deluxe platform results in less operator fatigue
•Best in class operator station adjusts to every operator
Kubota Seat
•Smaller seat, low back design
•Horizontal seat adjustment only with limited suspension
•No swivel on the seat and no weight adjustment
NH Hydrostatic Power Steering
Benefits
•Smooth effortless control, even with heavy loads
•Modern technology
•Steering rods protected behind axle
•Available with SuperSteer and Sensitrak
Value
•More responsive steering reduces cycle times
•No extra linkage, so fewer parts and more durable
•Steering rods and cylinder protected from damage
•Best manuverablity and smallest turning diameter in industry
Kubota Integral Power Assist Steering
•Increased steering efforts
•Steering rods in front of axle are more susceptible to
harm
•Old technology, slower response
New Holland Electrical Power
Benefits
•High capacity 40 amp alternator standard
•12 volt power socket
•Automotive style fuses
•Can operate additional functions
Value
•Better charging in cold weather climates
•Quick glowplug heating
•Additional accessory power
Kubota Weak Electrical Power
•14.4 amp Dynamo
•Extra cost for larger alternator
New Holland Heavy Duty Rear Axle
Benefits
•Rugged castings, heavy duty cast iron
•Extra strength, long life with heavy use
•1635 lb lift capacity
Value
•Heavier construction equals long term durability and
reliability
•Can handle heavier implements
•Safer, more stable tractor
Lighter Rear End
•Fabricated steel trumpet housings
•Lighter weight, less stable
•Less capacity for heavy implements
•1300 lb lift capacity
Heavy Duty Axle Hubs
Benefits
•Heavy duty design
•Large axle flange to distribute load
•8 bolt hubs
Value
•More durable equipment over long term
•More productive with larger, heavier tools
•Less likely to need repairs
Kubota Small Rear Axles
•Light weight axles
•Smaller axle flanges
•Only 6 bolt hubs
New Holland Serviceability
Benefits
•Can check oil without raising the hood
•Can gain complete access to engine
•Air cleaner restriction light
Value
•Convenient service saves time, more productive
•No tools required for routine maintenence
•Proper maintenance leads to longer life
Kubota Difficult Service Access
•Four, yes four panels to open / remove
•Must raise hood just to check oil, and dipstick is too
close to the exhaust pipe
•Requires a funnel to reach oil fill location
•Oil dipstick very close to muffler
New Holland 3-pt. Hitch Ability
Benefits
•Rugged, heavy construction
•1,635 lb. lift capacity
•Flex link ends, telescoping stabilizers, and adjustable/
swinging drawbar and crank style level adjustment
are standard deluxe equipment
Value
•More reliable in long term with heavy use
•Quicker, easier attachment and adjustment of implements
•Finish the job faster with larger implements
Kubota 3-pt. Hitch
•Light weight design
•1,300 lb. lift capacity
•Sway limiters are inside the 3-pt. and blocked when an
implement is attached
   / New buyer, there is a lot to consider, need help #12
Just curious, JT1972: are you a NH dealer or salesman?
Is there a reason that you haven't filled out your profile?
JT1972 - I welcome any info, but not clear on what this comparison is. Can you give me the models? The Kubota info listed is not correct for either of the tractors I am looking at and I'm not sure what model of NH you are referring to either.
   / New buyer, there is a lot to consider, need help #14
Bill you are just too darn skeptical . . . besides anyone can cut an paste the features from the NH website /forums/images/graemlins/wink.gif
All kidding aside, given the compramises that need to occur on this property over the next couple of years, Kubota might not be the best fit because there is a big gap between the B series and the Grand L series machines. There is the L3400 but it really doesn't compare in terms of feature sets. The desire for PTO horsepower, but the eventual need for smaller size for long terms jobs is what prompted me to point out the TC33. In terms oh HP it runs just a bit higher than the L3130 but in a package that is going to be between the B3030 and the L3130 with sophistication that is not found in the L3400. I'm sure there is a current model from JD that might also be a darn good fit, I just am not really up to speed on what their new model numbers are.
   / New buyer, there is a lot to consider, need help #15
Surely wish I had your delema. /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
I make do on 68 acres with a little Kubota B7100. Move rocks, haul logs, dig stumps, build roads and cultivate about 7 acres.
For your work I'd seriously consider a tractor of the B7800 size. Slower at first but more adaptable for the long run.
My only suggestion would be to go for loader abilities as it would appear to be the most used on the initial preparation.
Egon
   / New buyer, there is a lot to consider, need help #16
The Information posted would pertain to the TC29DA and TC33DA. Compared that to the B2910 which is now the B2630 and B3030. They have bumped the 3pt lift but the creature comforts haven't changed. Check out the toolbox, and cupholder on the B3030, these have changed.
   / New buyer, there is a lot to consider, need help #17
Bill,
Am neither a NH salesperson or dealer. Just have an interest in tractors and their is a ton of differences if you are a novice to the business as I once was. Just like to make sure apples are compared to apples. I just got onto this site, location is nortwest ohio, near Bryan. Will update
   / New buyer, there is a lot to consider, need help #18
Jerry,
With that bio, I'd say your credibility just went up. At least with me, anyway.
Welcome to TBN. I'm sure they will value your input in the NH forum.
I talked with the NH dealer today and it sounds like the TC33DA is a nice machine. It is almost identical to the L3400 in size, weight, and HP, but has some of the nice features included on the 3130. The FEL capacity falls between the L3400 and L3130. It is almost the same price as the L3130, which kind of suprised me. They don't have a 33 in stock, but I am going to look at a TC29 on Monday to get an idea of features, feel, etc.
   / New buyer, there is a lot to consider, need help #20
I'm a little biased here, owning the L3130, so take this all with a grain of salt... you will never be sorry having too much machine in the early stages of your project. The larger machine will also be able to do the small things but the smaller machine will simply not be up to the big jobs. During the early project stages the machine will work hard and definitley some of it's life and tightness will be used up. The smaller machine would suffer more so. If you start with the larger machine you will know within a year if it is just going to be too large for the future.
To have the best of both worlds consider this... buy the big one (L3130 really isn't all that big) and use it well and keep it if you find it suits you...or...trade it in after a year or so for a smaller one and get some attachments with the difference in value.
Best of luck,
Martin
2014 Ford Explorer SUV (A59231)
2014 Ford Explorer...
2015 KOMATSU WA270-7 WHEEL LOADER (A60429)
2015 KOMATSU...
2001 John Deere M665 60in Zero Turn Commercial Mower (A59228)
2001 John Deere...
LMC 6' SOIL CONDITIONER (A59823)
LMC 6' SOIL...
1996 FORD F SERIES DUMP TRUCK (A60430)
1996 FORD F SERIES...
UNUSED FUTURE 350 HYD BREAKER HAMMER (A52706)
UNUSED FUTURE 350...
