New buyer, there is a lot to consider, need help
   / New buyer, there is a lot to consider, need help #1
grwoolf
Bronze Member
Austin, TX
I am a first time tractor buyer. I’m leaning toward Kubota at this time. I like the local Kubota dealer and will probably go that route if I can work out a fair deal. I still plan to at least look at JD and NH before buying to make sure I have seen some other options.
How I’ll be using the tractor:
5 Acres, mostly flat, lots of rocks on 1/3 of it.
Primary use over the next 2 years is grading and spreading dirt, moving rocks, brush hog(would like 5ft), installing gravel driveway, putting in yard, landscaping. At some time in the future, I would probably get a pull behind finish mower to mow a couple acres.
Based on this, my primary concern is grading and FEL capability, and max HP for brushhogging.
I definitely want hydro drive, have rented tractors and backhoes many times and love this feature.
Right now, I am trying to decide between the L3400HST and the L3130HST with FEL. I would get the upgraded loader on the L3130. The L3130 is about $2k more.
Here is my current assessment:
L3400HST
Pros
-Price (save $2K)
-More Power at PTO (3.5 more)
-Lighter for Mowing (won’t tear up yard as bad)
Cons
-Jerky 3pt (I have read about this, will try out before going with this tractor – I don’t mind as long as I can precisely control a box blade
-Weaker/smaller FEL
-PTO? – not sure about this
L3130
Pros
-Stronger/Bigger FEL (one foot wider and 600 pounds more lift)
-Extendable Lower Links
-Very nice 3pt features and operation
-Seat, Ergonomics, quieter, etc. – not big deal to me, but worth something
-PTO - ? not sure if this is better, but hydraulic, independent
Cons
-Price (extra $2k)
-Power (probably good for 5ft brushhog, but not great)
-Weight (700+ pounds heavier – probably good for FEL and brushog work, but maybe a bit heavy to mow with)
What am I missing?
I am in $ creep mode on this. I started thinking maybe I could find a used tractor for $12k, then figured for a few grand more go new, another grand gets more HP, a couple more I can get the bigger FEL, etc., etc. I don’t want to overbuy, but don’t mind spending the extra $ if there is value.
Any advice/guidance anyone has would be appreciated. I also have a few other questions on these machines I hope someone can answer:
The L3130 FEL has an option for Skid steer quick release on the bucket. I assume this means I can use attachments for a skid steer. I think this is pretty new for Kubota, can anyone comment on this feature? What would be involved if I wanted to add hydraulic connections for a grapple hook or something. Is this possible? What would the cost be?
Tires – I am planning to go with the standard Ag tires, but will probably want to mow some day. Are the ag tires terrible for mowing? I imagine the industrials are better, but this is another $650, and I am already blowing my budget. If I want to switch to industrial tires later, do they go on the same wheel or is it a different diameter/width?
Can anyone explain the difference in the PTO’s between the L3400HST and the L3130? The 3400 says it is Live, continuous running and the L3130 is Independent. Does that mean the 3400 is controlled by engine speed while the 3130 will run at 540RPM at various engine speeds?
I am also looking at buying the Kubota Canopy for shade. It is like $350, but this is a lifesaver in the Texas summer sun. I don’t mind spending the money if this is well made, but wanted to see if there are any problems with this. I may need to fold down the ROPS to get into my garage, but the dealer said this is not a problem with the canopy and that it faces backward away from the tractor.
I am considering getting my tires filled with the goop to seal punctures. This dealer wants $200-$400 depending on the product, but it seems like a good thing long term. Any advice?
I am also thinking about a toothbar and it looks like the people on this site really like Markham welding, so I plan to go that route.
Is there anything else I am missing that is a must-have?
Thanks for any feedback or advice. Sorry for the long post, I probably should have broken this up into more than 1.
   / New buyer, there is a lot to consider, need help #2
Welcome,
I can't speak for the tractors you mention but do you really need such big tractors for 5 acres? And how big are these rocks?
Foam filling the tires is a preference to most people. To save a little money try without doing it and see how it goes. If you get flats all the time then fill them at a later date.
Markham does a top notch job for a fair (cheap) price. The toothbar is sweet.
Did you look at the B series?
   / New buyer, there is a lot to consider, need help #3
I have not compared the two tractors but the L3130 is similar to my L5030 and I bought it from Lanford in Austin. My manual covers the 3130. I'll try to answer a few of the questions.
The 3130 is rated to handle a 6' mower.
The skid steer attachments, for example Bobcat, can fit on the Kubota skid steer loader type attachment. I got two dealer installed remotes when I bought the tractor and ran a hydraulic hose to the front loader arm to connect to the Bobcat grapple bucket. Two remotes are expensive another thousand $, but are invaluable for box blade TnT work.
Last year Lanford had the Wells AG canopy which is very well made. I have one and is absolutely necessary for the Texas heat. It makes tractor work in the afternoon a JOY.
I got my tires filled with the multi seal. I have 40 acres of mesquite and have had no flats.
I have the industrial tires - They are wider so I am assuming the wheels are different. Wider is better in the sand for me.
The PTO is dependent on the engine speed on the L3130, but because of HST the ground speed is not.
Maybe some others will be able to answer your other questions. See you around!
   / New buyer, there is a lot to consider, need help #4
For 5 acres, I would look at a smaller tractor. The 2 you are looking at will be GREAT for your initial tasks for the first year or two. Both will be sub-standard for finish mowing a 2 acre yard. I'd downsize one notch and take a look at the next size down. A B3030 would do what you need, it would handle a lighter bushhog. It would be much better suited to your LONG term needs. It would be GOOD for the initial tasks for the first year or two, it would be GREAT after the property is tamed.
In the New Holland line take a look at the TC29 or TC33 (both are the same frame, they are ONLY diffent in the engine, the 33 has a few more ponies). These 2 models are in between the B3030 and and the L3130 in size, weight and capacity.
I'm not sure what JD has at about 28 to 30hp as they seem to be adding and dropping models now. Their old 32hp 4310 was a real beauty of a machine, but a bit larger than I'd suggest for long term, it is being phased out now. I'd probably look one size smaller for a long term use.
I think one thing to consider is that you have the need for 2 different tractors here. Tractor #1 is for the first 2 years. Tractor #2 is for years 3 to . . . I strongly consider you look at a compramise tractor. Find something that is NOT QUITE as big as you'd like for the first two years, but not TOO BIG for years 3 to . . .
Just my thoughts.
Thanks for the feedback. I absolutely understand that I really need one machine now and will have different needs later. I was orignially looking at the B3030 and B7800, but I just can't imagine being happy with the FEL performance on these. Both of these machines weigh under 2000 pounds. I have been renting skid steers and full sized back hoes for the last 9 months. I know that none of the B or L tractors will move material like those machines, but I still see a big different between the B's and L's just in terms of weight and the capacity of the FEL. In looking at the size/weight of these machines, the L just does not look very big to me and the B's look tiny. Maybe I'm underestimating the B3030.
   / New buyer, there is a lot to consider, need help #6
I don't think you are misunderstanding the B3030, it is light and far lower capacity than the L3130. That is sort of why I suggested the TC29/33 to you as an in-between machine because you indicated you wanted to check out New Holland. Compared to renting full size back hoes, an L series will seem small, but when that 2 acres becomes a lawn with flowers, shrubs and ornamental trees planted in it, the L will seem pretty large & heavy for mowing that area.
I will definitely check out the New Hollands. Thanks for the info.
   / New buyer, there is a lot to consider, need help #8
Don't forget the other brands near you too! Personally I think many of the machines out today are pretty darn good. I also think the dealer support is pretty important, a great machine from a lousy dealer can give you more grief than its worth, and a lousy machine from a great dealer isn't a bargain either. See what fits you best, see what you like, try the brands in your area and see what dealer seems to treat well, who can offer you support, and see what tractor will match most closely to your overall needs. The price, while important in the decision making process, will fade with time, and a bargain price up front will haunt you forever if you buy the wrong tractor. Find the best fit (machine size, dealer comfort level, machine layout, etc), regardless of brand, buy that one. You will be happiest with that tractor over time.
I am going to look at other options, especially the NH and JD, since there are dealers reasonably close. It really suprises me that there is such a lack of options in the Austin area. There are no Kioti or Mahindra dealers and you have to go about 30 miles from my work/house for a John Deere or New Holland dealer. This isn't a huge drive, but still a bit of a pain in the butt for service, maintenanace parts, etc.
   / New buyer, there is a lot to consider, need help #10
Personally, I wouldn't go too far for a dealer, it gets to a point where you almost have to have a trailer and a truck to haul the tractor back & forth for service, being close to a dealer often means pick up & delivery is free or at least a very modest cost. And when you factor in the price of trailer or the price of pick & delivery to a dealer, plus time investing (actually time lost) hauling it back and forth then the total cost of ownership begins to really climb. I like to deal locally for service, but I am lucky, I have all of the Big 3 brands within 8 miles of my house.
   / New buyer, there is a lot to consider, need help #11
Additional info:
New Holland Superior Operator Comfort
Benefits
•Deluxe cushioned seat
•Seat adjustment on incline/decline plane for optimum
visibility and access to controls.
•Weight control and swivel adjustment on seat
•Arm rests available
Value
•Better vision results in safer operation
•Deluxe platform results in less operator fatigue
•Best in class operator station adjusts to every operator
Kubota Seat
•Smaller seat, low back design
•Horizontal seat adjustment only with limited suspension
•No swivel on the seat and no weight adjustment
NH Hydrostatic Power Steering
Benefits
•Smooth effortless control, even with heavy loads
•Modern technology
•Steering rods protected behind axle
•Available with SuperSteer and Sensitrak
Value
•More responsive steering reduces cycle times
•No extra linkage, so fewer parts and more durable
•Steering rods and cylinder protected from damage
•Best manuverablity and smallest turning diameter in industry
Kubota Integral Power Assist Steering
•Increased steering efforts
•Steering rods in front of axle are more susceptible to
harm
•Old technology, slower response
New Holland Electrical Power
Benefits
•High capacity 40 amp alternator standard
•12 volt power socket
•Automotive style fuses
•Can operate additional functions
Value
•Better charging in cold weather climates
•Quick glowplug heating
•Additional accessory power
Kubota Weak Electrical Power
•14.4 amp Dynamo
•Extra cost for larger alternator
New Holland Heavy Duty Rear Axle
Benefits
•Rugged castings, heavy duty cast iron
•Extra strength, long life with heavy use
•1635 lb lift capacity
Value
•Heavier construction equals long term durability and
reliability
•Can handle heavier implements
•Safer, more stable tractor
Lighter Rear End
•Fabricated steel trumpet housings
•Lighter weight, less stable
•Less capacity for heavy implements
•1300 lb lift capacity
Heavy Duty Axle Hubs
Benefits
•Heavy duty design
•Large axle flange to distribute load
•8 bolt hubs
Value
•More durable equipment over long term
•More productive with larger, heavier tools
•Less likely to need repairs
Kubota Small Rear Axles
•Light weight axles
•Smaller axle flanges
•Only 6 bolt hubs
New Holland Serviceability
Benefits
•Can check oil without raising the hood
•Can gain complete access to engine
•Air cleaner restriction light
Value
•Convenient service saves time, more productive
•No tools required for routine maintenence
•Proper maintenance leads to longer life
Kubota Difficult Service Access
•Four, yes four panels to open / remove
•Must raise hood just to check oil, and dipstick is too
close to the exhaust pipe
•Requires a funnel to reach oil fill location
•Oil dipstick very close to muffler
New Holland 3-pt. Hitch Ability
Benefits
•Rugged, heavy construction
•1,635 lb. lift capacity
•Flex link ends, telescoping stabilizers, and adjustable/
swinging drawbar and crank style level adjustment
are standard deluxe equipment
Value
•More reliable in long term with heavy use
•Quicker, easier attachment and adjustment of implements
•Finish the job faster with larger implements
Kubota 3-pt. Hitch
•Light weight design
•1,300 lb. lift capacity
•Sway limiters are inside the 3-pt. and blocked when an
implement is attached
   / New buyer, there is a lot to consider, need help #12
Just curious, JT1972: are you a NH dealer or salesman?
Is there a reason that you haven't filled out your profile?
JT1972 - I welcome any info, but not clear on what this comparison is. Can you give me the models? The Kubota info listed is not correct for either of the tractors I am looking at and I'm not sure what model of NH you are referring to either.
   / New buyer, there is a lot to consider, need help #14
Bill you are just too darn skeptical . . . besides anyone can cut an paste the features from the NH website /forums/images/graemlins/wink.gif
All kidding aside, given the compramises that need to occur on this property over the next couple of years, Kubota might not be the best fit because there is a big gap between the B series and the Grand L series machines. There is the L3400 but it really doesn't compare in terms of feature sets. The desire for PTO horsepower, but the eventual need for smaller size for long terms jobs is what prompted me to point out the TC33. In terms oh HP it runs just a bit higher than the L3130 but in a package that is going to be between the B3030 and the L3130 with sophistication that is not found in the L3400. I'm sure there is a current model from JD that might also be a darn good fit, I just am not really up to speed on what their new model numbers are.
   / New buyer, there is a lot to consider, need help #15
Surely wish I had your delema. /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
I make do on 68 acres with a little Kubota B7100. Move rocks, haul logs, dig stumps, build roads and cultivate about 7 acres.
For your work I'd seriously consider a tractor of the B7800 size. Slower at first but more adaptable for the long run.
My only suggestion would be to go for loader abilities as it would appear to be the most used on the initial preparation.
Egon
   / New buyer, there is a lot to consider, need help #16
The Information posted would pertain to the TC29DA and TC33DA. Compared that to the B2910 which is now the B2630 and B3030. They have bumped the 3pt lift but the creature comforts haven't changed. Check out the toolbox, and cupholder on the B3030, these have changed.
   / New buyer, there is a lot to consider, need help #17
Bill,
Am neither a NH salesperson or dealer. Just have an interest in tractors and their is a ton of differences if you are a novice to the business as I once was. Just like to make sure apples are compared to apples. I just got onto this site, location is nortwest ohio, near Bryan. Will update
   / New buyer, there is a lot to consider, need help #18
Jerry,
With that bio, I'd say your credibility just went up. At least with me, anyway.
Welcome to TBN. I'm sure they will value your input in the NH forum.
I talked with the NH dealer today and it sounds like the TC33DA is a nice machine. It is almost identical to the L3400 in size, weight, and HP, but has some of the nice features included on the 3130. The FEL capacity falls between the L3400 and L3130. It is almost the same price as the L3130, which kind of suprised me. They don't have a 33 in stock, but I am going to look at a TC29 on Monday to get an idea of features, feel, etc.
   / New buyer, there is a lot to consider, need help #20
I'm a little biased here, owning the L3130, so take this all with a grain of salt... you will never be sorry having too much machine in the early stages of your project. The larger machine will also be able to do the small things but the smaller machine will simply not be up to the big jobs. During the early project stages the machine will work hard and definitley some of it's life and tightness will be used up. The smaller machine would suffer more so. If you start with the larger machine you will know within a year if it is just going to be too large for the future.
To have the best of both worlds consider this... buy the big one (L3130 really isn't all that big) and use it well and keep it if you find it suits you...or...trade it in after a year or so for a smaller one and get some attachments with the difference in value.
Best of luck,
Martin
2017 BX2680 Sub Compact Utility Tractor (A56438)
2017 BX2680 Sub...
FORKLIFT (A56857)
FORKLIFT (A56857)
2024 CATERPILLAR 930 AG HANDLER WHEEL LOADER (A60429)
2024 CATERPILLAR...
2022 FREIGHTLINER M2 BOX TRUCK (A59905)
2022 FREIGHTLINER...
2007 MACK GRANITE CV713 DUMP TRUCK (A60430)
2007 MACK GRANITE...
2013 CATERPILLAR 299D SKID STEER (A60429)
2013 CATERPILLAR...
