New Branson 3820!
/ New Branson 3820! #1
Strongman
Southeast Michigan
Thanks in part to all of your input, I bought my Branson 3820 yesterday with a BL20A loader and Kodiak 6' rotary cutter. I should get it delivered on Wednesday after they fill the tires. I thought I would give everyone some of the details for potential buyers and mention some of the items that have been brought up in previous posts.
I paid $16,000 for the 3820 (replaced the 3520) with the BL20A loader, R4 industrial tires, and $850 for a Kodiak (light duty) 6' rotary cutter (just maintaning the edge of fields with it). I also paid $320 for putting 35 gallons of Rimguard in each tire with tubes. I realize someone mentioned that you don't have to use tubes but about half of the companies I talked to about loading the tires with rimguard said they won't fill them unless they had tubes in them because the Rimguard is so slippery and they can lose a lot getting the tires sealed again. One person said under high torque conditions you could break the seal (I question that) and if you do get a leak, it is much harder to fix if you don't have tubes because of the mess around the rim. It only cost an additional $60 for tubes, so I thought it was worth it.
I found it was worth it to shop around, I called 4 dealers in Michigan. The store 13 miles from us was $1200 more for the same setup than what I paid. I ended up going 100 miles away to A.J Rental Equipment (they don't rent the Bransons) in Standish who makes their money on volume and sells for a lower price. They gave me free delivery. They said they will pretty much deliver anywhere in Michigan.
The tractor had 8 hours on it from people trying it out. I had never driven a compact tractor before, but after a few minutes felt quite comfortable on it. I had a lot of "book knowledge" from reading all the threads here but no hands on experience. We talked about some of the problems others have had on this site with the Branson/Centurys and it sounds like Branson has fixed all the ones I can remember (i.e. needing a check valve to prevent fuel from running out of the line after setting awhile, fixing the water problem in the turn signal connector, and the poor users manual). The users manual is about 1 1/2" thick, has nice print (in English) and looks quite complete - and covers the Cummins engine.
Speaking of warrenty issues, the 3820 has the new Cummins engine in it (the website falsely says it's a 3 cylinder - but it is a 4 cylinder) and comes with a 3 year warrenty. He also said that Branson is starting to pay the dealers to go and pick up the tractors from the customer and haul it back to their shop to perform warrenty work (I would assume only if it is a major problem). I asked the dealer to contact Branson and see if there are any service buletins on my tractor before they deliver it just in case.
I called Branson and they said they don't make the 3520 anymore but they do still make the BL20 loader as well as the BL20A loader right now, so make sure you check which one the dealer is offering. They are also offering 0% financing for up to 36 months OR a $600 rebate. Branson only mentioned the 0% and the dealer only mentioned the $600 rebate.
One last item, especially related to the earlier post today about the Diesel fuel geling. Since I've never used diesel fuel before I didn't realize that "on the road diesel" (Number 1 diesel?) that is more expensive (it has road tax) is the type you want in cold weather. When Branson puts fuel in the tractors, they use the Red off road diesel (Number 2 diesel?) because probably it is cheaper and it is in Georgia where they normally don't get down in the low temperatures. The dealer I bought my tractor from didn't get the red off road diesel out of a new 4220 tractor in time and now they cannot start it (they said mine had the Number 1 diesel in it). Someone in this users group mentioned that their tractor uses about a gallon of diesel an hour - to me it is worth the little extra for the "good stuff".
Sorry for the long post but I wanted to give something back for all the great information I received - Thanks Guys!
/ New Branson 3820! #2
congratulations!!
I'm sure you'll dig yer new toy..err...machine!
I thought it was the best bang for the buck..
As far as your fuel situation...you can put an addidtive in your off road fuel..thats what I do. I use powerservice you can get it at wally waorld among other places. I use twice the reccomended dosage on the white bottle and have no issues.
It keeps my GM/stanadyne Inj pump happy...trust me these gm pumps are hard to keep happy.
One thing you'll want to think about is lights for your rollbar. One century/braqnson drawback is the headlites are low hard to see with the FEL up more than 6 inches. Micropilot turmed me onto a way to mount them that doesn't void the warranty.
When yer ready post and we'll give ya all sorts of good advice on mounting them up.
read the book from stem to stern, ask questions and practice. /forums/images/graemlins/cool.gif
/ New Branson 3820! #3
Congratulations!!
#1 diesel fuel has less btu's and less lubrication than #2 diesel. Others advice to use #2 and additive like powerservice will keep wear to a minimum. Red dye = #2 no road tax paid - about $0.40 gal in MN.
Truckers around here mix #1 & #2 50/50 when it gets -30 F, less #1 up to about +35F at 0%. Pumps are side by side & don't have to carry an extra jug around. They say the cost premium of powerservice equals mixing #1 and dropping MPG.
I just add powerservice in the diesel machines in the Fall & am covered for any temp variable, less smoke etc.
/ New Branson 3820! #4
Congrats !! I bet you can't wait to get that baby home. I know I counted tractors in my sleep while I was in the waiting period for mine. That was a killer!
I hope you enjoy many fine hours tractoring on that machine. If you enjoy yours half as much as I do mine, then you will be OK.
Of course, now you must know that your tractor becomes a real tool, when you get the attachments. The more attachments, the more of a tool it becomes. It's a never ending cycle...as you should have picked up on by reading this forum....but it is a hoot and a heck of a ride.
Enjoy, and good luck. Keep us informed....warts and all. (hopefully no warts).
sassafraspete
/ New Branson 3820! #5
Yep, what Pete said, my life was incomplete without my tractor /forums/images/graemlins/wink.gif
If anything things sure get done faster and easy.
Good luck with it, be safe and have fun!
Gene
/ New Branson 3820! #6
Congrats and have fun! It won't be long before you'll wonder how you survived life without it!
/ New Branson 3820! #7
<font color="blue"> They are also offering 0% financing for up to 36 months OR a $600 rebate. Branson only mentioned the 0% and the dealer only mentioned the $600 rebate.
</font>
I was at a dealer last week and they only had 0% for 12 months, and they didn't mention any rebate. Branson's website seems incomplete in their financing and dealer information. It would give a potential buyer more confidence if they would spend a few bucks to make their information consistent and available to everyone. Branson, however, is hardly alone in online incompleteness: CaseIH doesn't even have pictures of their compact tractors! That 0% for 36 or $600 back deal sounds good, though.
/ New Branson 3820! #8
Just depends on who the dealer is using for a finance company.The company I use has 0% for 36 mo or $600 rebate.IMHO take the rebate and pay a little more interest. /forums/images/graemlins/shocked.gif
/ New Branson 3820! #9
</font><font color="blue" class="small">( Just depends on who the dealer is using for a finance company.The company I use has 0% for 36 mo or $600 rebate.IMHO take the rebate and pay a little more interest. /forums/images/graemlins/shocked.gif )</font>
If you take the rebate on a $20,000 tractor you would still be financing $20,000.
Assuming a 3 year term at %7 interest and putting your $600 rebate as an extra payment to pay down the principal you would end up paying over $2,000 in interest.
You'd be better off taking the %0 interest deal.
/ New Branson 3820! #10
I think that you will find with most manufactures that the programs do change on a monthly or quarterly basis that could be the reason for the different rates or discounts
/ New Branson 3820! #11
Micropilot,
You are absolutely correct. In this case you would be better off by paying $600 more for the tractor up front.
What the customer (and the dealer) need to pay attention to is the rebate amount AND the cost of financiing at current standard market rates.
Rebates should be looked at for what they are----upfront costs for getting lower interest rates (or in financial lingo--buydowns).
By running the numbers, (using an amortization calculator), a savy buyer can determine if there are actual cost savings, using the low rate offers.
dancce
/ New Branson 3820! #12
Every copy of Excel and Works Spreadsheet has a Loan Amortization template for running these kinds of scenarios. Thats what I used!
/ New Branson 3820! #13
Micropilot
That all works fine if one can afford the payments. Some time speading the loan out over a longer time frame is the only way one can afford the monthly payments. Even if that means paying a higher rate.
Happy Tractoring
Chipperman /forums/images/graemlins/smile.gif /forums/images/graemlins/smile.gif
/ New Branson 3820! #14
True and I understand this because it's what I did. I wish I could afford $600/month!!
TRAILER (A66736)
TRAILER (A66736)
2017 Toyota Tacoma 4x4 Ext. Cab Pickup Truck (A66736)
2017 Toyota Tacoma...
Unused 2024 Schulte 5026 26ft. Batwing Hydraulic Rotary Brush Cutter Tractor Attachment (A66734)
Unused 2024...
2019 ALLMAND LIGHT PLANT (A67714)
2019 ALLMAND LIGHT...
PORTA POTTY (A68842)
2012 HARDEEBILT 827PEQ6 EQUIPMENT TRAILER (A66091)
2012 HARDEEBILT...
