New Battery
/ New Battery #1
chris laws
kubota L1801DT
Hi guys I have a kubota l1801dt compact and need to purchase a new battery the old one has no information on it and am not sure what to buy
/ New Battery #2
Get dimensions of battery (L X W X H) and positive post position (Left or right) and x-reference it to chart of known battery sizes...
/ New Battery #3
... need to purchase a new battery the old one has no information on it and am not sure what to buy
What @DL Meisen writes is good. What I do is I try to find the biggest battery (CCA number) that physically fits in the existing space. I have found that most tractors and farm stuff has a little more room than what the OEM battery is using. So, taking the size space I can measure, I turn to the Battery Group Size Chart, make sure terminals locations work, and find what can fit. Then I look for that size or sizes that a battery seller has available. My objective is to get the highest CCA so the battery always has more to give than necessary - which correlates directly to battery life for me.
/ New Battery
Thanks to you all I will be right now and get the biggest cca that fits
/ New Battery #5
Two years ago I went from the OEM battery on my 2009 Kubota M6040 to an Odyssey AGM battery. I had to really dig into my Op manual but finally found that it was a group 31 battery.
Minus any references in your Op manual - what D L Meisen says - post#2 - is the way to go.
/ New Battery #6
Yep, I do the same. I shove the largest battery that it will fit in the compartment. Always check to make sure the +/- are on the right sides though...
/ New Battery
I purchased the biggest battery that fits with 700 cca so tnknks all for your input 🤓👍
8ft. 3 Point Blade (A65640)
8ft. 3 Point Blade...
Mini Universal Tree Spade (A65640)
Mini Universal...
2016 WEILER P385A ASPHALT PAVER (A62129)
2016 WEILER P385A...
Gehl Mix-All 95 Grinder Mixer (A66408)
Gehl Mix-All 95...
ACS PORTABLE AIR COMPRESSOR (A64276)
ACS PORTABLE AIR...
2019 FORD F-250 SUPER DUTY (A65643)
2019 FORD F-250...
