New Battery
   / New Battery #1
chris laws
kubota L1801DT
Hi guys I have a kubota l1801dt compact and need to purchase a new battery the old one has no information on it and am not sure what to buy
   / New Battery #2
Get dimensions of battery (L X W X H) and positive post position (Left or right) and x-reference it to chart of known battery sizes...
   / New Battery #3
... need to purchase a new battery the old one has no information on it and am not sure what to buy
What @DL Meisen writes is good. What I do is I try to find the biggest battery (CCA number) that physically fits in the existing space. I have found that most tractors and farm stuff has a little more room than what the OEM battery is using. So, taking the size space I can measure, I turn to the Battery Group Size Chart, make sure terminals locations work, and find what can fit. Then I look for that size or sizes that a battery seller has available. My objective is to get the highest CCA so the battery always has more to give than necessary - which correlates directly to battery life for me.
   / New Battery
Thanks to you all I will be right now and get the biggest cca that fits
   / New Battery #5
Two years ago I went from the OEM battery on my 2009 Kubota M6040 to an Odyssey AGM battery. I had to really dig into my Op manual but finally found that it was a group 31 battery.
Minus any references in your Op manual - what D L Meisen says - post#2 - is the way to go.
   / New Battery #6
Yep, I do the same. I shove the largest battery that it will fit in the compartment. Always check to make sure the +/- are on the right sides though...
   / New Battery
I purchased the biggest battery that fits with 700 cca so tnknks all for your input 🤓👍
2013 Cadillac SRX (A50324)
2013 Cadillac SRX...
200722 (A51247)
200722 (A51247)
2022 CHEVROLET 2500HD CREW CAB TRUCK (A51406)
2022 CHEVROLET...
2019 CATERPILLAR CS44B SMOOTH DRUM ROLLER (A52705)
2019 CATERPILLAR...
UNUSED IRANCH IRMC HIGH END ELECTRIC MASSAGE CHAIR (A54757)
UNUSED IRANCH IRMC...
Pair of New 700/40-225 Alliance Tires with Rims (A55301)
Pair of New...
