New Battery terminology??
   / New Battery terminology?? #1
chopped
New England yankeee
I am considering buying a small tester device. And se they say it uses a 9v reduplicated battery:confused2: .
I assume this is a standard 9 volt battery and the word duplicated is reference to rechargable?
Sometimes hard to decipher the foreign terminology :confused3:lol
Here is a link to the device.
Thanks
Hand-held Wire RJ45 RJ11 Ethernet Network LAN Cable Tester With 9 LED Lights | eBay
PS> I usually do a search to find out what things mean but come up blank with this one..:laughing:
   / New Battery terminology?? #2
Thanks
Like you I would assume that means 9V rechargeable battery in Chinglish. But note they do not include a charger, so you are going to be out for battery and charger, It is not clear if the remote needs a battery, probably not as this is just a wire mapper type device. I am wondering if a regular 9V alkaline battery would not be fine. There is a difference in voltages though for the 9 volt Ni-cad or NiMh. batteries and regular alkaline batteries.
James K0UA
Thanks I agree with you, Im assuming its a language thing I did some more looking and found the same device for the same price and it says just 9 volt battery..
Its kind of interesting to see how things are described from china.lol
I had a 2000 dollar piece of equipment that had a cheap china switch to it, and Th main manual said to reference the switch directions that came with the switch. I opened the paper with the switch and it was in chineze..lol
   / New Battery terminology?? #6
ha.. me too!.. and I am the one that used the word!.. I did not know it was a real word.
James K0UA
LINCOLN ELECTRIC RANGER 225 GAS WELDER/GENERATOR (A54757)
LINCOLN ELECTRIC...
2011 Kubota KX080-3 Midi Excavator (A56857)
2011 Kubota...
CASE IH MX220 MAGNUM TRACTOR (A57192)
CASE IH MX220...
2023 Kubota L3560 Compact Utility Tractor with LA805 Front Loader (A56435)
2023 Kubota L3560...
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2018 Ford F-150...
2007 Sterling L9500 (A55973)
2007 Sterling...
