New barn build – compressed air question
   / New barn build – compressed air question #1
turbo36
Michigan
JD X739 AWS (3), 2016 Toolcat, JD 2038R
I am building a new 44’ x 48’ workshop that will be next to my existing 40’ x 60, barn. Instead of buying a new compressor for the new workshop, I am thinking about running a 200 psi rated black polyethylene pipe from from the existing barn to the new barn. Any opinions?
   / New barn build – compressed air question #3
Is polyethylene approved for air service. I remember reading a few years ago not to use plastic for air service but that may have been PVC.
Will this be overhead or under ground between the buildings?
   / New barn build – compressed air question #5
How about steel black pipe?
   / New barn build – compressed air question #6
I would suggest an analysis of what you need for CFM of your tools. If all you need is to fill a tire than you do not need a lot of CFM flow. If you want to run air tolls then you need the CFM at a certain pressure.
One option would be to put a storage tank in the second building and have a smaller line fill it. The tank providing the initial burst and then recharge via the smaller line from building 1.
You need to look at what you want to do before deciding a path to follow.
As some said above, plastic is not your ideal option.
It would be buried underground, I plan on having a 100 gallon surge tank in the new barn. seeing that it is rated at 200 psi I don’t see a problem as my system pressure would be 150 psi max.
   / New barn build – compressed air question #8
If you are gonna run pipe use the largest diameter you can afford, up to a point. The longer the run the larger the pipe. People make the mistake of using higher pressure to make up for pressure drop over long distances. This is truly a big mistake. This scheme results in much more water in the air delivered. And also in energy wasted. This wasted energy shows itself in higher power bills and less air delivered. And water in the air. So, decide yourself if the piping you want to use is up to then task but then make sure to use large diameter pipe. Over 20 years ago I went through all the calculations required when I installed new air piping in a machine shop I worked in. Being a machinist and not a pneumatic engineer I ended up learning a lot. But the biggest item that could ruin the whole thing was piping that was too small and pressure that was too high for the job. You really want the pressure delivered from the compressor to be not much higher than the system pressure and you want the piping to be large enough to avoid pressure drop that is below what the tools being powered require. It is a BAD thing to have your air powered tools or air guns lose power. This at the very least causes water to drop out of the compressed air which then flows along the bottom of the plumbing until it comes out of your air tool or air gun. The compressor should be up to the task and then some. Probably twice for a home shop.
Eric
polyethylene pipe is approved for air service, it will also survive freezing as most of the underground sprinkler lines are polyethylene.
Essentially, I am looking for any insight from someone has done this before and ran into some problems that I could not foresee.
   / New barn build – compressed air question #10
I'd consider running it inside a larger pipe as a casing so, when it needs replacing, you don't have to dig again.
401 (A52706)
401 (A52706)
PALLET OF SCAFFOLDING (APPROX. 18 PC) (A52706)
PALLET OF...
Kuhns AE10 Small Square Bale Accumulator - 10-Bale Efficient Handling System (A55301)
Kuhns AE10 Small...
2019 TRAIL KING INDUSTRIES ADVANTAGE PLUS TRIAXLE RGN W/FLIP AXLE (A55745)
2019 TRAIL KING...
2000 John Deere 1860, 30ft Wide, Gandy Box, Wing Fold, 7.5in Spacing (A53472)
2000 John Deere...
2015 Freightliner Cascadia 125 Day Cab Truck, VIN # 3AKJGEBG5FSGD4138 (A54865)
2015 Freightliner...
