New B7100 HST member/owner
   / New B7100 HST member/owner #1
grossgary
midatlantic
1994 Kubota B7100 HST 4WD
Howdy folks. I picked up a B7100 and look forward to getting to know this forum and the tractor. I have a few questions and hope this isn't "Overload" for you guys! I'm new to tractors and diesels but have tons of auto experience so hopefully i can catch on.
Any tips on where to start? What kind/weight of oil do I use?
Is the "Operators Manual" good to have? Looking for something that tells basic fluid types/weights, maintenance schedules, and maybe some basic info on tune-ups/maintenance.
Are the multi-tractor IT workshop manuals good or not? Or should I try and find the Kubota shop manuals?
How do I figure out how to hook up my 60" deck? Looks like some bolts/pins may be missing. Some of the attach points look obvious, like the 3 bolt brackets on each side, but the rest I'm not sure about.
I saw some deck manuals on ebay. How do I know which deck I have? There appear to be multiple 60" decks with slightly different numbers.
I'd like a temp and oil pressure gauge, I'll do some searching but figure this is something that's common.
   / New B7100 HST member/owner #2
Do you know about how old that B7100 is? There's a considerable difference in the early ones vs. the later models; both were good; just different. Of course, I bought my 1995 B7100 new so I got the Owner's Manual with it, and I would highly recommend that you try to obtain that. If you can't find it on the Internet, you should contact a dealer. Do you have a front end loader? And if so, which model? I did not buy the Workshop Manual or the Illustrated Parts List for the B7100, but I did buy them when I bought a 1999 B2710. They go together, are quite expensive, but very good.
I did not like the lack of a temperature gauge on the B7100, but as the factory rep told me, "if it gets hot, you'll hear it whistle". That never happened with mine. You know it had no water pump or coolant recovery jug which was new to me at the time.
Hope you enjoy that tractor, and welcome to Tractorbynet.
Oh yeah I was told it's a 1994 by the previous owner. 3 cylinder 16 hp diesel dual range 4WD HST.
No, it did not come with a bucket. It came with a Kubota 60" MMM (mid mount mower is what MMM seems to mean from reading) and some non-Kubota attachments.
Wow, no water pump or recovery jug. That is bizarre, I'll try to keep my auto knowledge from getting in the way here!
Thanks, I'll work on finding those manuals.
   / New B7100 HST member/owner #4
I'm sure that 1994 is the same as the 1995 I had. But I had the B1630C front end loader and no MMM. I used a Bush Hog RTS40 tiller and a Bush Hog SQ48 brush hog, a cultivator plow, and a middle buster, but back then I had a Cub Cadet lawn tractor for my finish mowing. And in 1995, the thermosiphon system with no water pump was new to me, too.
   / New B7100 HST member/owner #5
if u pm me i have the shop manual in pdf form i got years ago as far as mmm there are 3 points on mine one in front under rad. one on each side just forward of rear wheels it is a pull and twist job on mine it has a loader though. and also the twist pull things are gone too many trips in woods for logs. I use a 5/8 bolt i just ground down alittle on bench grinder and drill to make it fit or was it a 3/4 bolt hmmmm my memory if failing o no lol
anyway havehad mine for about 5or 6 years and did a little upgrade to it look in sig line at link
yes power steering works grrrrreatttttttttt
rohttp://www.tractorbynet.com/forums/images/editor/separator.gifbbieo11 said:
wow great, i'll PM you!
the 60" MMM had all the mounting hardware removed, the brackets, arms and everything. i think i figured it out though. i mowed with it yesterday even though some bolts/parts are missing. i'll replace those shortly.
nice work on the power steering. i have a welder and would love an excuse to buy a cutter, but that kind of custom work is over my head! awesome job.
   / New B7100 HST member/owner #7
get a pic in your head and think HOW nice it would be or even just scratch some drawigs on paper it will come to u i was told by people NOT on this board it could not be done yes some where mechanical engineers
did you get my PM? thanks for all the feedback everyone, this is a fantastic resource.
New Wolverine72 In Skid Steer Brush Cutter (A53002)
New Wolverine72 In...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
2013 INTERNATIONAL PAYSTAR DAY CAB ROAD TRACTOR (A51406)
2013 INTERNATIONAL...
378741 (A51572)
378741 (A51572)
New/Unused 9.5ft 30 Drawer 2 Cabinet Workbench (A51573)
New/Unused 9.5ft...
