New B3030 Cup Holder
   / New B3030 Cup Holder #1
vic4news
Merrimack County, NH
Kubota B3030
The cup holder on the B3030 is behind the seat .
This location is great for keeping you back muscles loose since you need to pivot your body to reach it.
However, I sometimes I just want a drink instead of a stretching routine,
so I mounted a new one on the right fender.
Vic
   / New B3030 Cup Holder #2
nice! More pics on how you did it would be great.
B3030 cupholder is awesome
for holding bolts and odds and ends.
sux for drinks
I had a 4" pvc drain pipe coupling left over from installing new drain pipe from the day before.
I just cut a notch for the cup handle, and a triangle shaped notch in the bottom so it fit against the handrail on the fender.
I painted it black and attached it with one screw into the side of the plastic lever housing. The lever housing has thick plastic areas for the fender screws, so I attached it in one of these areas.
I'll be trying it out tomorrow morning.
For the other side, I think I'll weld something up out of steel rod. Should look better and be fun to make.
Vic
I made a second cup holder for the other fender. This one attaches using one of the studs in the handrail. No modifications to the tractor needed.
I used 1/8" rod and a piece of flat plate.
Vic
(click on thumbnails)
   / New B3030 Cup Holder #6
Great idea ! Agreed, the factory cup holder is better suited to hold odds and ends. I like the idea of a more convenient and comfortable beer holder (as i prefer to call them).
   / New B3030 Cup Holder #7
Mine has a built-in cup holder in the right fender just before the fender turns down. You can kinda see it in this pic.
   / New B3030 Cup Holder #8
I see that you use your ROPS as a towel rack also... Thought it was only me!
mark
20' Multi Door One Way Ship Container (A52384)
20' Multi Door One...
ASSET DESCRIPTIONS & CONDITION (A52576)
ASSET DESCRIPTIONS...
BESTWAY AG VSK35 LOT NUMBER 126 (A53084)
BESTWAY AG VSK35...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A52377)
2003 Big Tex 10PI...
Honda EU3000is Gasoline Companion Inverter Generators (A51691)
Honda EU3000is...
