New add on grapple
   / New add on grapple #11
Welcome to TBN
Great addition to your tractor :thumbsup: You will find it extremely useful for all kinds of stuff. Logs, brush, rocks, ........ Mine is a similar bolt on grapple. I couldn't live w/o it. You have better teeth than on mine. I welded some teeth on my grapple fingers right off then later added some to the bucket edge. Helps to grip hard slippery, frozen or wet, logs like beech. The teeth are pieces of 1/2" rebar.
What type of grapple is that?
   / New add on grapple #13
I like the teeth on the sides of the bucket shown in post #4...
In my "good idea" sketch book I'm going to note this. However, I'm thinking about a bolt on flat bar stock with teeth cut in it.
   / New add on grapple #14
I know this is an old post but found a 1700 for sale kind of local. I need something with a grapple to start cleaning up all the downed trees from Hurricane Micahel. Can you expand on the "diverter valve for control "?
A diverter valve is an electrically operated solenoid valve that will allow you to selectively operate 2 functions from one existing control valve. (Think of it as a A-B selector switch for hydraulics)
In a grapple type set-up it it usually installed between the loader valve and the curl/dump lines on your loader with a single push button switch on your loader control stick.
In the Normal (Off) position your loader control stick operates the curl/dump function as normal. in the Diverted (On) position the loader control now opens/closes the grapple INSTEAD of curl/dump of the bucket.
The biggest thing to watch out for is whether or not your loader valve has a "Regen" or "Fast Dump" mode on it. If so you may have issues depending on how that's configured.
   / New add on grapple #15
Homemade piranha bar all the way around. I like it
2017 VOLVO VNL TANDEM AXLE DAY CAB (A58018)
2017 VOLVO VNL...
2004 INTERNATIONAL DURASTAR 4300 BOX TRUCK (A55745)
2004 INTERNATIONAL...
KENWORTH W900B (A58214)
KENWORTH W900B...
2021 Ford F-250 (A55973)
2021 Ford F-250...
Cushman Electric Cart (A55853)
Cushman Electric...
2021 Ford F-150 4x4 Ext. Cab Pickup Truck (A54814)
2021 Ford F-150...
