LD1
Epic Contributor
The 11-hole drawbar that goes on the 3PH will do most of what you need.
There is tons of reading here about the dangers of pulling with the 3PH, and ways to overcome that danger (like the vertical straps pictured).
IF you plan to put a ball on the drawbar you need to do something to keep it from rotating. There are several things that can do that. There are pieces that go around the drawbar and attach to the lift arm, and there are also vertical pieces that bolt on and you can use the toplink. Or you can just get one of the 3-pt trailer mover attachments.
The only time my factory drawbar gets used on my kubota is to chain it down to the trailer.
