New 790 - FEL issue
   / New 790 - FEL issue #11
My dealer found the same thing on my 790 as well with the oil suction tube. He did put his pressure gauges on the hydraulic system and adjusted the pressure up on my pump. He said that the pump was putting out 2300 psi and he moved it up to 2800 psi. He will be dropping it off Friday, so I'll try it out and let everyone know
   / New 790 - FEL issue #12
So where is it exactly that you need to look to see if your tractor is having this issue or not? Can you crawl underneath it and look at something before complaining to your dealer and then not having anything wrong at all in the end??
   / New 790 - FEL issue #14
I move bales with my 4720 all the time on the 400X with a bale spear. I need one on the rear to cut my work time in half. Keep them as low as you can without messing the bale up, but it seems fine to me.
D.
2015 FORD F-150XL SINGLE CAB TRUCK (A51406)
2015 FORD F-150XL...
Walinga Agri-Vac (A50514)
Walinga Agri-Vac...
more info coming soon! (A50323)
more info coming...
2021 CATERPILLAR 259D3 SKID STEER (A51242)
2021 CATERPILLAR...
Quick Attach EZ Axe Skid Steer Tree Shear (A52128)
Quick Attach EZ...
2022 Polaris General 1000XP UTV (A50514)
2022 Polaris...
