New 5v tin over old 5v tin?
   / New 5v tin over old 5v tin? #11
Maybe I'm missing something, but if you're taking the nails out what's holding the panels on? It seem like it would be incredibly unsafe to be on the roof with all the panels un-nailed. At that point removing the panels is just a matter of lowering them to the ground, a negligible amount of work.
I believe the O.P. was talking about just knocking the lead coverings off of the nail heads and leaving the nails in the old panels. Some of those lead heads fly off when originally pounding those nails in and some actually end up in the rain gutters over time. That had been my experience with my 40+ year old roofing.
   / New 5v tin over old 5v tin? #12
There could also be an issue with galvanic corrosion if the old metal is left...
Curious...is the underside of the metal also rusted?
   / New 5v tin over old 5v tin? #13
If you want the building to last I would remove the old roof.
I just got my home roof replaced with 29 ga. metal roof.
I priced the metal before I had the roofer do it and this metal is called "Galvalume" and costs $1.44 a linear foot (1' X 3').
It is much better than 5V.
Also they screwed it down in the rib not the flat and he said the engineers approved of this.
My roof is permitted and inspected. Roofer has his own machine to make the panels!
I'm fixing to put a metal roof on my hunting camp that I am building and I am determined to screw mine in the ridge as well, this goes against most any advice that I have been given, but I have done a couple of barns and I have had more issues with the one I screwed in the fiat than the ones screwed or nailed in the ridge, glad to here some are still doing it this way.
   / New 5v tin over old 5v tin? #14
You just need to be very cautious not to over tighten if screwing in the ridge. Pre drilling helps.
I wasn't gonna remove the nails, just the lead that is under the nail heads. This type of nail seems obsolete now, but they were used in 1979. You drove the nail in and the lead flattened out and prevented a leak. The lead served the same purpose as rubber washers do now. You can run a crowbar down the v and the lead is easy to break loose, then the new sheet will flat on the old one.
Selling the old tin is a good idea. It seems unanimous that I need to remove the old roof, so we will go that way. Thanks for all the replies.
   / New 5v tin over old 5v tin? #16
Don't forget to gather the lead, it's probably worth more than the old tin.
   / New 5v tin over old 5v tin? #17
I need 2200 sqft of old 5v for a project! Where are you located?
   / New 5v tin over old 5v tin? #18
Here's one case against in the ridge.
Screw Location Recommendations - YouTube
   / New 5v tin over old 5v tin? #19
Yes sir and that goes hand in hand with what most people tell you about why it is better to screw the tin in the flat, but a lot of those same people say exposed fasteners were never supposed to be used on residential roofs only agricultural type setups, I'm still going in the ridge as water can't stand on the ridge.
16ft T/A Flatbed Trailer (A55758)
16ft T/A Flatbed...
2015 International 4400 SBA Gap Vac Truck (A53117)
2015 International...
JCB 2145 (A47477)
JCB 2145 (A47477)
BUSH HOG 1815R1 BATWING MOWER (A51247)
BUSH HOG 1815R1...
(4) New Winch Straps (A54865)
(4) New Winch...
