Backhoe new 4672 A backhoe problem
/ new 4672 A backhoe problem #1
wstacy
California
B7800
I've only put a few hours on this and already one of the boom lock pins is missing in action. /forums/images/graemlins/frown.gif It's the one closest to the operator, and it seems to have ripped out. Is this thing just pressed in or what? I cant find it, so I'm not sure how it attaches. The parts diagrams are not very helpful. It looks to me like the pin does not mate up with any hole or anything on the other side of the boom. The lock itself is bent and I'm not sure how or what I did to do that. Any ideas?
/ new 4672 A backhoe problem #2
There are 2 boom lock pins (sort of) I can think of. One is for rotation (left/right), which just drops down by gravity into a receiving hole once the spring pin is removed. The other is for the up/down, which holds a sort of link about 8" long with one 3/4" hole at each end. That link basically spans 2 3/4" pins, and is held in place with 2 spring clips, when the boom is all the way up to prevent 'droop' during transport. My link lasted about 1 week: its not designed to tolerate, for instance, bumping into a pile of eath with the hoe whilst loading.
My brother made me a new one.
Are these what you are referring to?
Yes, it's the strap that connects the two pins that got bent and one of the pins with its cotter got lost. It looks like this pin (closest to operator) could also be a travel stop for the boom's upward travel, except that such a pin would logically penetrate the opposite side of the boom, and there is no such hole. So I'm thinking it's a real short pin and am not sure what its attachment to the boom is (guessing pressed in since I see no evidence of threads). I can hammer the strap straight, but need the part I.D. for that pin and its fastener if any. Sounds like this is a very tender and maybe useless item? /forums/images/graemlins/mad.gif
/ new 4672 A backhoe problem #4
Wstacy,
I have attached a photo, actually 3, of my 4672. It shows it locked in position and then a front view and back view of the pin (I think) you are describing. The pin is welded and flush on the back side. Hope this helps.
Greg
/ new 4672 A backhoe problem #5
That pin should have been very firmly welded into place - I scrapped the link and the pin(s) on my hoe weren't even scratched. It seems to me possible that the weld and/or assembly was defective. Maybe it was tack-welded into place and forgotten. As the photos show, there should be quite a weld fillet (or whatever you call it) if the pin tore off.
You might consider contacting the dealer and or Kubota for a warranty claim.
If this isn't an option, have a machine shop make a clone of the other pin (basically a 3/4 dowel welded onto or through a 1/4 plate) and have it arc welded into place.
/ new 4672 A backhoe problem #6
MIne came out too, but it was clearly my fault. I tried moving the boom to install the BH without removing the lock strap, and it pulled ou the pin. I still haven't tried to reinstall it.
/ new 4672 A backhoe problem #7
Well I'll be....
Mine came out this weekend. Its not our fault - its a lousy design. The pin is lightly welded from the back. They might as well have peaned it on! /forums/images/graemlins/mad.gif
I will follow my own advice and make a plate/pin that'll be welded together, then installed and welded from the back, and the plate will be be welded on. Other than a crash, there is no reason this should have come out. /forums/images/graemlins/mad.gif
Kubota now admits it's a defect. That little pin must be flush on the inside of the boom, and needs a substantial weld/plate on the outside just like the more aft one. They are sending a replacement part to my dealer, who hopefully will come out with a portable welding rig and make it right under warranty. I will report back if/when this all happens. /forums/images/graemlins/smile.gif
/ new 4672 A backhoe problem #9
Please do let us know how it goes - and a part number if you get one. My backhoe is outa warranty, but I can try and get them at least to give me the replacement part.
/ new 4672 A backhoe problem #10
I was talking with my dealer today and brought up this issue. He said this is a fairly common problem. He also said that they don't cover it under warranty. He brought up the point that the pin is made to break out when enough force is exerted on it to protect the boom & dipper from being damaged. Basically the pin is designed similar to a shear pin. So far I think I have been lucky. Even the dealer said he had accidently tried to use a BH with it in the locked position. I am definitely going to try to be more careful in the future though.
Thanks for the post,
Greg
/ new 4672 A backhoe problem #11
I'm sure the Kubota dealer thinks it a feature, but the relief valve protects the boom from being damaged while using the hoe. At least thats the way it should work - there is no way the boom hydraulics can damage the hoe. In reverse (i.e. backing into a solid object) the boom would tuck in and you'd have to bend a lot of metal to damage it. Pin or no pin, if you could damage it, you would.
The transport pins and lock are supposed to be a safety feature, not a shear pin. My link was damaged all to easily, and the pin came out a year and a half later for no particular reason. I can't imagine what would happen if the tractor was being transported and the pin popped out. It could be catastrophic.
In my machine as the pin pulled out it bent the base of hoe a bit. If it had been reinforced properly that shouldn't of happened.
I had a Case backhoe with a honking 1" transport pin. It was not a shear pin. It didn't have a link, but the clasp for it was shaped so it would sort of play if you backed into something. If I can figure out how to do it, I'll modify my link with an oval hole or something to have the same effect.
My pin is in and it will be covered under warranty. However, my dealer doesn't have a mobile welder so I have to take it in. Will try to remember to get the part number. I think the fix will be to weld a little extra reinforcement plate like was done on the aft pin. I don't think it should be a "shear" pin, and Kubota seems to agree. Now I get to figure out how to tie that boom securely on the trailer... I got to Kubota by e-mailing their web site. Gotta love the internet... /forums/images/graemlins/smirk.gif
/ new 4672 A backhoe problem #13
I'm glad to hear about your fix and that it is covered by warranty. The more I got to thinking about the "shear pin" theory, the less I agreed with it. Keep us posted about the fix. If you could attach a pic, I'd like to see what the finished product looks like.
Thanks,
Greg
/ new 4672 A backhoe problem #14
All you guys are afraid to weld to your rops, But you'll weld on the boom?
Danny
2013 Kubota BX2370 54in 4x4 Compact Utility Tractor Mower with 48in Rotary Brush Cutter (A61572)
2013 Kubota BX2370...
2016 WESTERN STAR 5700 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2016 WESTERN STAR...
2019 Westinghouse WSTBT1503 Wireless Speaker (A61574)
2019 Westinghouse...
2016 RAM 5500 Bucket Truck - Cummins Diesel - Auto Trans - 4X4 - Terex LT40 Boom (A61306)
2016 RAM 5500...
2014 BMW X1 S28i SUV (A61574)
2014 BMW X1 S28i...
2019 Jayco Octane T32H Toy Hauler (A62613)
2019 Jayco Octane...
