NEw 4610
   / NEw 4610 #1
REX
Amherst, Virginia
Kubota/4610
Would like to know several things. What is a fair price on a new L4610 with Loader, and can the L4610 handle a 7' cutter/medium duty or should I consider smaller. Thanks in advance.
   / NEw 4610 #2
$23,000 would be a good price, but not reasonable in all markets. The best way to get an idea of what the tractor will actually cost you to buy, is to request a quote from 3-5 dealers in your region/area. Don't forget options, tires, setup, delivery, etc. Tires alone can change a price quite a bit on the L4610, as can a number of options available.
7' would be the largest cutter you would ever want to put on the L4610... depends on your application. I wouldn't go beyond 6' unless you have a light duty use for the cutter. Regular mowing of a controlled field, for example. Even then, you're beyond any suggested use for a 7' medium duty cutter.
Irrigation Pump with John Deere 4045 Engine (A52128)
Irrigation Pump...
2014 INTERNATIONAL LF687(INOPERABLE) (A50854)
2014 INTERNATIONAL...
2020 John Deere 160G Excavator (A47384)
2020 John Deere...
2014 ORTEQ ENERGY SERVICES MANIFOLD TRAILER (A50854)
2014 ORTEQ ENERGY...
2016 CATERPILLAR D5K2 LGP CRAWLER DOZER (A51242)
2016 CATERPILLAR...
5-Bottom Plow (A52128)
