New 4530
   / New 4530 #1
Egg Man
Eastern Shore Maryland
Mahindra 4530
A couple of questions if I may... Cold start aid light no longer coming on when key is on. Does anyone know if it is thermostatically controlled as it still starts fine and it hasn't been very cold lately. The manual does not mention if it is or not. Also, it never really reads over about 150 degrees on the temp gauge when running. Manual claims normal operating temp is 180 degrees. Again no operating issues, just doesn't seem right. So far, a great tractor.
   / New 4530 #2
The bulb on the cold starting aid light may be burned out. That has happened on my 6000. It works fine, but light does not come on.
The temp gauge issue may relate to how hard you are running the tractor. The more you put it under load, the more likely you will see the more normal temp indications.
   / New 4530
Tonight when I fed livestock, the light came on, go figure, probably a bad connection. I'll keep my eye on the engine temp. Thanks.
   / New 4530 #4
Havent had any issues out of my light, but far as the temp, the only time mine gets up around 180 is when i am using the brush hog, but just doing light work, it seems to take awhile to get it warm.
   / New 4530
Thanks, did some loader work yesterday and noticed the temp starting to climb. Not worried about the light, seems to be ok now. What type of skid steer bale spear do you use and do you like it? I will need to get one this year.
   / New 4530 #6
I have an Ottawa adapter on my fel. When you remove the bucket, the spears pin directly to the adapter frame. Wish I had a pic but I don't right now.
   / New 4530 #7
Sorry for waiting so long to reply, I have the Armstrong forklift attachment, then i bought a spear and socket, and two spikes, and welded the sockets on, now i can either use forks or bale spear on one frame.
2022 Massey Ferguson 1825E 4WD Tractor (A50860)
2022 Massey...
2013 Ford F-150 4x4 Pickup Truck (A48081)
2013 Ford F-150...
Vacuworx Vacuum Lifter Pad (A50860)
Vacuworx Vacuum...
2018 Ford F-250 Ext. Cab Reading Enclosed Service Truck (A48081)
2018 Ford F-250...
Hay Fork (A50860)
Hay Fork (A50860)
2016 New Holland B95CLR Loader Backhoe (A50860)
2016 New Holland...
