New 4520r smell drives me nuts
   / New 4520r smell drives me nuts #1
YanmarFever
Elite Member
Eating a melon..
Mahindra 5010C- Branson 4520r- 5520C- Yanmar FX235-D - Bad Boy rogue mower
I have a new 4520r (24 hrs) on the meter.
The smell that comes out of the exhaust from having to keep the revs up kinda makes me noxious.
What can 1 do to get rid of the fumes?:confused:
Love the tractor, it does everything I need it to do.
   / New 4520r smell drives me nuts #2
I think you mean nauseous. Anyhow - which way is the exhaust pointing. On my tractor the upper two feet or so can be rotated in any direction.
Look for a clamp on end pipe that can be rotated away from the drivers area. Rather than a vertical exhaust - can a horizontal exhaust be fitted as an after market add on.
There is no product, that I'm aware of, that will significantly alter the smell of diesel exhaust.
Unless you go to biodiesel that is made from french fry oil............. now THAT would make me upchuck.
   / New 4520r smell drives me nuts #3
The Bransons have a front facing exhaust tailpipe that's not adjustable.
I find that my 3725 exhaust smells less after I have worked it hard. I did a bunch of idling recently while unloading the backhoe I bought from the trailer and hooking it up to the tractor and the exhaust started smelling more. It's not the usual untreated diesel stink which I hate, it's more like the smell that modern diesel road vehicles make.
   / New 4520r smell drives me nuts #4
is it fuel or tractor related? could you use offroad diesel
   / New 4520r smell drives me nuts #5
All diesel fuel dyed or undyed is the same.
My tractor exhaust don't bother me as much as my pickup does,
I can have a tractor running in a shed or garage for a few minutes with no problem,
let my little diesel pickup just back in for a minute to unload and can't stand it.
   / New 4520r smell drives me nuts #6
I avoid bio diesel due to cold weather concerns, but if your climate is better and you have it available give it a try.
   / New 4520r smell drives me nuts #7
Has the OP worked the tractor yet so it burns off any paint or other coatings inside the exhaust? What fuel, fuel treatments/dosages, and emissions are we dealing with?
   / New 4520r smell drives me nuts #8
By the way you're stating things, is the "smell" worse at high rpms, vs. low rpms or idle?
And I'm wondering too if everything is just so new, that "stuff" is still burning off of the manifold and exhaust.
And what fuel are you running? Are you putting any additives in it? Are you still burning off your tank of winter fuel? I notice a difference in the way my exhaust smells when running straight summer red dye, vs winter red and Power Service additive mixed in it.
Its the DPF soot cooker muffler, the smell just bugs me when the wind blows it toward me.
It smells bad..
   / New 4520r smell drives me nuts #10
I've talked to my local dealer about the soot cooker many times. He's told me that on his personal Branson tractor, when he lets his get to the point where the light starts blinking, he then takes it out and works it very hard to clear it. During this "work very hard to clear it" phase, he says his stinks with a heavy burning plastic smell. This lasts until such time as the cooker burns itself clear, and then the light goes out, and the smell stops.
Perhaps yours is in the middle of burning itself clear, and it will just take a while. As in being run for an extended period of time?
Maybe just take it out and road it down the road in high gear and run the beegeezuss out of it?
Is your dpf light blinking, or on?
2020 KOMATSU PC360LC-11 EXCAVATOR (A51246)
2020 KOMATSU...
2017 TAKEUCHI TB240 EXCAVATOR (A51246)
2017 TAKEUCHI...
2018 CATERPILLAR 299D2 SKID STEER (A51246)
2018 CATERPILLAR...
RYOBI 18V BRUSHLESS ELECTRIC 20" PUSH MOWRE (A51248)
RYOBI 18V...
(2) UNUSED 7000# DROP AXLES W/ BRAKES (A51247)
(2) UNUSED 7000#...
