New 4025 4wd
   / New 4025 4wd #1
CarlV
East TN
Dealer delivered Friday and spent the weekend doing some light clearing getting used to the controls. Got a bh860 backhoe and 6ft box blade with it. I dropped the bh to use the boxblade sat morning. Few hours later i went back to hook the bh back up and one of the quick connects would not reattach. Was finally able to get the fitting on, but took well over an hour. Is there a way to prevent the hydro pressure from building up?
   / New 4025 4wd #2
dont connect the ones on the bh together...leave them uncoupled...made the same mistake the first time
   / New 4025 4wd #3
Cycle the control levers before you disconnect it, which will relieve pressure in the lines. Should be standard practice for any hydraulic implement that you plan to disconnect.
   / New 4025 4wd
That makes sense, but wouldnt i Have to set it on blocks in order to not move or drop it on the ground? Dealer unattached it and hooked it back up before he left, but didnt mention doing that. Thanks!
   / New 4025 4wd #5
...engine off...
you may want to consider Skid Steer connectors. They are flat faced, more expensive, but do provide easier coupling, with lines loaded as well.
   / New 4025 4wd
Thanks guys I will try that. Very new to tractors, was around them as a kid, but its been a while. Got a 6ft box blade and used it some. Should I use the lower connecting pins for the 3pt hitch or the tops ones with the boxblade?
   / New 4025 4wd
Another question, Using the boxblade the blade would float when it starting to dig in. How do i turn off the draft control?
   / New 4025 4wd #8
Fairly new myself but I had the same problem. I had left DC on about mid-way from when I was bush hogging. Loosen the thumbscrew and push your DC lever all the way down for using the box blade. It makes a world of difference. Oh and not sure what you mean about top ones and lower ones when referring to the pins, but to operate the box blade or any other 3pt implement, you are going to have to attach both lower arms and your upper arm to make it work.:thumbsup:
D
   / New 4025 4wd
Thanks deisaroo. I did have the draft all the way down, it just seemed too sensitive and would not stay engaged well. First little resisitance and it would raise up just a little. There are two connection points on the tractor for the lower arms. Do you use the upper or lower with the box blade?
   / New 4025 4wd #10
Box Blades just work off of force/weight. It will need to start building up dirt before it really gets to digging since there is no down pressure on most utility tractor 3pnt systems. The angle of the boxblade will determine how well it digs also.
SHOPBUILT 40FT FLARE STACK (A52472)
SHOPBUILT 40FT...
2018 DandA 220V Hydraulic Breaker Excavator Attachment (A51691)
2018 DandA 220V...
2022 JOHN DEERE 410E II (A52472)
2022 JOHN DEERE...
Kubota Salt-Spreader (A52384)
Kubota...
Toro Mower (A50324)
Toro Mower (A50324)
2012 FORD F-650 ROUSTABOUT TRUCK(INOPERABLE) (A52472)
2012 FORD F-650...
