New 3430 arrives
   / New 3430 arrives
Yep - this climate and scenery was a major reason for moving here - lake, mountains and orchards make a nice combination.
The tractor came from Valley Tractor in Wenatchee, WA. They sell Kubota and John Deere, but many more orange tractors than green in the orchards around here.
15 hours on the tractor in the first week. The only problem I had was hitting the telescoping lift arm clip on the 3-pt with the swing cylinder when swinging the hoe around. Mostly my fault since I had the 3-pt lift arms raised up a bit for clearance. The clip is bent pretty good but still works. I need to adjust the bottom position of the arms a bit higher, probably because of the lower profile of the R4s.
I did some BH digging yesterday and the hoe seems pretty effective. I can overdig to the point where I need to back the bucket out a bit, but i think thats technique more than anything else. I have noticed that I can't seem to move boom and dipper at the same time, but being a BH rookie I'm not sure if this is expected or not. The swing speed adjustment is nice but I wish there was adjustment to slow down the boom drop rate a bit.
The only other comment I have is that I'm glad I went for the 3430 rather than 3130. With the weight of the BH, loader and loaded tires, I pretty much need to use low range for any significant inclines. M really starts to lug quickly. Haven't even tried H range.
   / New 3430 arrives #12
pgmmaf said:
It's finally here :D Delivered this afternoon: 3430HST, R4 tires, LA723 with quick-attach HD bucket, Woods BH90-X with thumb, Woods HSS72 rotary cutter and Woods RB72 rear blade.
Beautiful machine and wonderful countryside. I used went to WSU in Pullman a long long time ago.
Bob
   / New 3430 arrives #13
That's a very impressive machine you've got there, and beautiful country to work it in.
I wish you the best of luck with it!
   / New 3430 arrives #14
That is one great looking machine and your countryside is spectacular. Good Luck with your tractor.
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55301)
NEW HOLLAND 706 30...
1979 MACK R MODEL WINCH TRUCK (A53843)
1979 MACK R MODEL...
2016 E-Z Beever M12R Towable Brush Chipper (A51691)
2016 E-Z Beever...
2024 JOHN DEERE 8R 280 LOT NUMBER 7 (A53084)
2024 JOHN DEERE 8R...
197711 (A51244)
197711 (A51244)
2015 Volvo VNL 64T (A55218)
2015 Volvo VNL 64T...
