New 3010 owner
   / New 3010 owner #1
Anonymous Poster
Epic Contributor
New 3010 owner
I just want to say thanks to all you people out there for your knowledge and advice. It helped me make my decision and it helped at the dealer that I knew a little about what I wanted to buy. Looking forward to spending time on my Kubota and with you folks on TBN....Thanks again
   / New 3010 owner #2
Re: New 3010 owner
Congratulations on the new tractor! I got mine in July and have been amazed at everything you can do with it. It's a great machine and will serve you well.
GS
   / New 3010 owner #3
Re: New 3010 owner
Congratulation to you also. I also received my 3010 in July. Did you get the fel with it. Is it gst or hst. Whatever you have you will enjoy. I enjoy mine too much. Have already 128 hrs. on it. It runs everyday and doing plenty nice work. I know you will enjoy.
James
   / New 3010 owner
Re: New 3010 owner
I got the FEL and HST which took some getting used to after 21 yrs with a Farmall.Only got 6 hrs on it, I'm a little nervous about using it too much ,I don't want to screw something up. A friend told me to just go out and work the hell out of it, it can take the work load. I guess I'm a little too careful but I want to be sure I break it in right, the dealer said not to run it wide open for the first 50 hrs.and that's about it. Any tips on break in? PS it sure is a pretty tractor
   / New 3010 owner #5
Re: New 3010 owner
If you do a search on break-in, you'll find more opinions on break-in recommendations than you can shake a stick at.
Most of them seem to boil down to:
1. Use common-sense.
2. Don't use full-throttle for extended periods of time. ( but do use it if not doing so would cause the tractor to bog down and lug the engine )
3. Vary your RPM's through a fairly wide range. ( choose the RPM 'needed' for the task at hand. )
Good luck with your new 3010. A friend of mine has a 3010 GST and it is a handy little tractor.
-larry
   / New 3010 owner #6
Re: New 3010 owner
Hi Roadtrash, I have a new L3010 HST w FEL...its one amazing machine...I have 60 hours on mine and I just love to sit in the shop and look at it. The FEL is one tool I didn't think I'd use much, my neighbor has a 4300 JD with a FEL and he said get it you won't reqret it. I use mine all the time, probably the most useful implement I own. With the bushhog on the back and the bucket on the front I can do major damage to overgrown ditch banks and around fields. You can even trim trees if you hit the limbs just right....lol...I hope you enjoy yours as much as I enjoy my machine.
PS ....my neighbor wants to hook them together and see who can pull who....I think I can take him pretty easily.
Have a great day and be careful.
Steve
2012 Ram 3500 Crew Cab S/A Mason Dump Truck (A50323)
2012 Ram 3500 Crew...
Kubota GR2120 (A47384)
2013 Jeep Patriot Sport 4WD SUV (A50324)
2013 Jeep Patriot...
2013 John Deere 310SK (A47384)
2013 John Deere...
2011 GMC Acadia SLE SUV (A50324)
2011 GMC Acadia...
2021 Honda TRX 420 4x4 ATV (A50324)
2021 Honda TRX 420...
