New 2nd Rear remote leaking wo attachments
   / New 2nd Rear remote leaking wo attachments #1
Kendrick
Vermont
DK45S(Cab)
I finally got around to using my remotes the other week. Got my mower hoses changed out so I could connect. stuck it on A while using it I accidently grabbed the c-d lever. after working both I realised it was the wrong one and used the a-b lever. when I got off to fix a plug I noticed that the c-d ports were leeking a little. I figured no biggie. now this week while I mowed my hay I noticed a puddle of hydro fluid on by backhoe reciever which is under the remotes. when I looked the c-d remotes were still leaking. just a drop every min or so. I need some help tracing all the lines on the hydro system to make sure that the valve they installed is not broken/leaking internaly.
Any one who suggests take it to the delaler, not happening. im not going to trust them on somthing they messed up. Wallice or one of you guys input would be appriciated.
   / New 2nd Rear remote leaking wo attachments #2
Is it leaking from the ports or is it leaking from the steel lines under the tractor?
the lines will be going in (standing at the back) to the right of your top link they go into the valve that is located under the seat platform..there is a piece of rubber flap hanging down push that out of your way so you can reach in there and feel if any of the steel line are wet?
If you need to access the valve ther is a plate in the wheel well that you can remove so you can gain good access.
using the rear remote picure from this thread
http://www.tractorbynet.com/forums/kioti-owning-operating/124221-arrived-today-limited-edition-20th.html#post1429750
the black band that retains the plug is where it is dripping off of it is coming i think from the threads at the rear where it is hooked to the hard lines. I am concerned that if the fittings here are leaking they may also be doing so from the valve as well. The valve was actuated 1ce in both directions so the presure would have been taken off of the last "return" port but both were leaking I will try to get a pic of it tomorrow. The pannel you mentioned is behind the wheel correct? and not the one behind the tractor.
   / New 2nd Rear remote leaking wo attachments #4
Correct it will be in the wheel well, you will have to remove the tire.
(INOP )JOHN DEERE RIDING MOWER (A58374)
(INOP )JOHN DEERE...
toro lawn mower (A56857)
toro lawn mower...
New/Unused 8in Bucket (A57454)
New/Unused 8in...
2020 TAKEUCHI TB260 EXCAVATOR (A52709)
2020 TAKEUCHI...
2012 VOLVO VNL (A55745)
2012 VOLVO VNL...
2012 KIA Optima (A56859)
2012 KIA Optima...
