New 2615 Break In Ideas
/ New 2615 Break In Ideas #1
thl
Bridgeport Michigan
Kubota B2150
I've got a new 2615 with about 20 hours on it. The manual says to break in the tractor doing 'field work' for the first 50 hours. It has been used to move round bales a bit but does need to be broke in properly. The problem is that I'm in MI and field work is not possible at this time. Any alternative ideas as to a proper way to break in the tractor would be appeciated.
Thanks,
Terry
/ New 2615 Break In Ideas #2
Don't let it idle for extended periods. Try to get heat into the engine and work it best you can. Just Put it under load as soon as you can.
