New 260 bogging
   / New 260 bogging #1
Brushhill dave
central alberta
kubota 2360,Ford 4610,111jd,gt200 husky
My new 260(4 cord cut) is bogging down when in wood and slow to rev up. Air filer is clean, fuel is fresh. My question: do new saws come detuned??
   / New 260 bogging #2
New saws come set lean due to EPA regs and usually the dealer will set them up fairly well within the limits of the tabs. I would start by replacing the plug if this is a new condition after several tankfuls.
   / New 260 bogging #3
How sharp is your chain?
   / New 260 bogging
Chain is sharp, i don't let them get too dull
   / New 260 bogging #5
Those 260s are legendary saws and dependable as gravity so I don't think you have anything more than a carb adjustment issue. If it is a new saw and under warranty I would take it to the dealer. Usually when a saw bogs down and won't accelerate either unloaded or not it is the L (low) speed carb screw needs richened up a tad. Turn the screw counter clockwise 1/4 of a turn and see what happens. Good luck with your saw
Steve:thumbsup:
   / New 260 bogging #7
Dave,
Did you try to adjust your carb yet? What happened?
   / New 260 bogging
No, I had started night shift the day you suggested I should, it's gonna be a long run but will let you know when I get a chance to adjust
2008 JLG 450AJ SERIES II TELESCOPIC MANLIFT (A51242)
2008 JLG 450AJ...
Glenco Disk Chisel (A50515)
Glenco Disk Chisel...
2022 Adams CLC-1013 Conveyor - New (A52748)
2022 Adams...
2018 John Deere 331G Compact Track Loader Skid Steer (A50322)
2018 John Deere...
M & W Little Red Wagon (A50515)
M & W Little Red...
2025 Quality Steel 6' x 14' Utility Trailer (A50515)
2025 Quality Steel...
