New 244J photos
/ New 244J photos #1
DUSTMAKER
Wa
PT1445/Cat307 Excavator/komatsu WA180 Wheel Loader/cat D3C/Deere 244J
New machine was delivered yesterday. The ride control is awesome, clean air conditioned cab is great.
/ New 244J photos
Two more.
/ New 244J photos #3
You towed that machine with a toyota tundra? WTF? That's got to weight over 10k right? It's a nice machine though good luck with it.
Matt T.:D
/ New 244J photos #4
That was my thought! wow thats crazy. I would think class 5 truck or larger!
The machine looks great though!
/ New 244J photos #6
Cool machine! The place I get my mulch uses one similar. You should have a blast with it!
/ New 244J photos
I put about 6 hours on the new machine today, works fantastic. No I did not tow it with the Tundra, just had it hooked up to my trailer to stabilize it for load testing. I do pull that trailer hauling my Power-trac 1445 at about 7,500 gross though. I am still looking for a truck to haul the 244J on that trailer. Probably only need to move it 6 to 8 times a year so I don't want to spend a lot of money but the truck will need to pull the load and haul the bucket, flail mower and forks on a flat bed.
Regards
Paul
/ New 244J photos #8
That trailer's not going to hold up too long having 11500 on a 12k trailer. Even if it was just for testing. What are you using the loader for?
Matt T.:D
/ New 244J photos
Matt, I am using the loader for construction, landscaping and general utility work, snow plowing mowing with flail mower etc. The trailer is rated for 14,000k gross 12k axles 2k on the pintle, without the bucket it should be right at gross weight.
Paul
/ New 244J photos #10
and how much does the trailer weigh????
that counts against the gross.
/ New 244J photos
Trailer weighs 3,300, loader weighs 10,640 without operator or anything on the front end. That is probably a little low on the loader weight, I have added a few options, going to have to put it on scales. And then there is tie downs.
Paul
/ New 244J photos #12
How does the flail work on the loader? I was going to sub a buddy with a volvo mini loader but it seemed hard to use with out a hydrostatic trans.
/ New 244J photos #13
Deere claims the loader weights 11500lbs+. So between the tractor and trailer your about 15k give or take. I was wondering about the flail mower also can you share the details?
Matt T.:D
/ New 244J photos
That is the listed operating weight (11,552) with 1yard bucket,full fuel and 175lb operator. The 1yard bucket weighs 736. I don't have a flail mower yet, was going to rent one to experiment with first. The accelerator is really easy to hold the engine rpm where you want and the inching pedal makes it easy to adjust speed. I would think the Volvo would be even easier if you had their hand throttle control and hand adjustable inching valve. However the Volvo's foot inching pedal was a lot harder to push and maintain a slower speed with higher throttle settings.
/ New 244J photos
This is the universal skid steer QA adapter I am going to use for some of my attachments including the flail mower. Deer calls it there Worksite pro.
Paul
/ New 244J photos #16
Dustmaker
I have been reading your (old) thread from 2008 about your 244j loader. As I am thinking about getting one I am wondering how you feel about yours after four years if you still have it?
Would love any comments you have as well as any new pictures.
karlg
