New 2305! I'm an idiot...
/ New 2305! I'm an idiot... #81
Comical post. I added a 4 diamond wrap to my wife's original engagement ring for our 20th. Two diamonds on each side, stepping down in size. She loves the look of it and likes that the original is part of the whole. Sentimental like that.
So, where's the pictures? It's not real without pictures ;)
/ New 2305! I'm an idiot... #82
Congrats Steve! I'm glad your wait is finally over.
You are now the newest host to a terrific incurable infectious disease! :thumbsup:
Hey guys,
Well, I got a few hours of seat time today, it was fun to play. Mowed some and played with the backhoe. I'm going to have to look at that deck adjuster knob, tried every position and it still wouldn't stay in the raised position. Any trick to pulling off the floorboard? I didn't really look to hard when I was outside. I have yet to take off the BH and loader. Wanted to play today, not try to figure all that out. I know it's easy, just felt like driving it.
The wife came home and saw me mowing with the loader and BH on, she made an "L" on her forehead, must have been for love right? I told her that I loved her too. She did tell me to move a couple of cement planters that have been in the way since last year, I slide them in the loader and away I went, right on the front porch! I don't think she was all that impressed, but it's something! Oh, don't worry about her wanting to drive it, I'm telling ya, she has no interest.
Thanks for all of your collective help thus far, you have all been great. I'm sure I'll have plenty of questions coming. Chris, I'll be trying out the forks this weekend, can't wait!
Thanks again! :thumbsup:
Steve
/ New 2305! I'm an idiot... #84
Forks are a very useful tool, and I've been surprised how many different jobs I have found them good for. I just need to get my quick change loader attachment tuned so the bucket, and forks interchange more easily. My treatments now make wrestling with them very difficult, but I know it's a quick fix for my dealer. and I'm getting a liist of things together for him to look at. Of course I wouldn't be surprised if he tried gently to sell me another small tractor to use while this one is in the shop......... can't go through withdrawal can we? Johnthomas, help me out here! I know you have found ways to resist the urge! :D :D
/ New 2305! I'm an idiot... #85
Next time try dropping the whole FEL and BH to mow. With practice you can drop both in under 5 minutes. A 16" chunk of 8x8 or railroad tie under the BH makes it much easier. You'll be surprised how nimble the 2305 feels and how nicely it treats your lawn with the weight gone.
You don't need to remove the floorboards to muck with the knob. Remove the deck instead; it's easier. But for starters, remove neither.
Follow these steps:
Raise the deck fully.
Turn the knob to lock position.
Lower the deck.
Look at the gap between the lift arm and the stop *with the deck on.* It's between arm A and stop B in this picture. If your deck is drifting down this is probably a big gap.
Raise the deck.
Turn the knob to install position.
Lower the deck to the ground.
Disconnect linkage "C." Tigheten it until you think the gap between "A" and "B" will be about 2mm when the knob is in the lock position.
Lather, rinse, repeat until it's no more than 2mm on both sides.
The manual tells you to make this adjustment with the deck off; this will result in your deck being too low. You need to look at the gap with the deck weight on the arms. You may also need to tighten or loosen the front yoke as you do this.
Now that you mention it, I do recall reading about that gap, I will take a look tomorrow. I'm sure the tractor mows better without all the weight. To be honest, I wanted to see what it would do to the yard. It's been very wet and the turf faired well. I don't think the extra bouncing helped the cut any however. I will mess with the deck tomorrow and practice removing the bh and loader, looks pretty easy. That's a big reason I went with the ind. lift, so I didn't have to mess with the 3 pt. hitch all the time when removing the BH. Thanks again for the advise!
By the way, I didn't feel like an idiot! In fact, I went around and cut the unsold lots (just one pass along the road) on my street to tidy it up some. When I get some time, I'll take a picture of what I was using to cut with next to the 2305.
Steve
Follow these steps:
Lower the deck.
Raise the deck.
/ New 2305! I'm an idiot... #87
If you thought the cut was OK with the 1200lbs of FEL & BH, you will get a BIG FAT GRIN when you cut without them. It's really a big difference! :D
The main trick to removing & adding the BH & FEL quickly is shutting down the engine and equalizing hydraulic pressure before you connect or disconnect hoses. With practice you won't hesitate to add or drop them as needed.
That 62C really eats up some lawn, doesn't it? Can't wait to see how wide your old deck was...
/ New 2305! I'm an idiot... #88
Hey guys,
Steve
We had the same issue with ours and had to take it back to the dealer a couple of times.
I was going to mess with it but ended up contacting the dealer. They are going to pick it up today and bring back Friday. Figure I can be without for a couple days, looks like rain anyway. Hope they get it fixed the first time!
Well, getting pretty good at removing the BH and loader, nothing to it. It really does handle and mow better without the mass and weight. I was surprised how stable it is on the hills. There were some areas I was concerned about, but no problem at all, and yes I was wearing my seat belt! I was going to add wheel spacers, but I might hold off and see how it goes.
Steve
/ New 2305! I'm an idiot... #91
I guess she did mention last year that she liked this one.:shocked:
Now, now there is nothing wrong with a Northwest Tiller as it will break ground to 14 inches deep in one pass, eliminate hardpan, and the ground will be ready to plant the same day, and if she buys it you need to order the bed building attachment to build raised beds and have your corn come up 2 weeks sooner.:thumbsup:
/ New 2305! I'm an idiot... #92
Steve
Just a reminder - with that BH subframe on, you'll need rear spacers if you want to run chains in the winter.
Follow these steps:
Lower the deck.
Raise the deck.
So the dealer ended up coming to pick-up the tractor and 'fixing' the deck to bring back 2 days later. Well, it came back and the deck did hold in the locked position, although still too low. after I took a look, I realized the front was at least one hole lower than the rear and the deck still wasn't adjusted up as high as it can be. I proceeded to raise the rear hangers to get the proper 1/16" clearance between the lift arm and stop. Adjusted side to side so it was exactly level, then raised the front hangers to level front to rear. Not too bad of a job. Can get it cut up to 4 1/2" now.
I don't know how in the world they let it go out like that. One glance and you could see the deck pitched forward. I thought spending that kind of cash might warrant some descent service? So here's the kicker, after I got done adjusting the deck I noticed there was no fluid showing in the trans sight glass. It has seemed a bit loud, but that is to be expected with the hydro. Anyway, don't know how low I am, I'm wondering if they didn't top it off when they added the backhoe? I assume the whole system works of the same fluid?
I'm going to call tomorrow and see if they will come out and drop-off trans fluid and possibly add it. I just want it to be known by the dealer how low it was if there should be a problem. I've only put 8-10 hours on it so hopefully everything is good. It may not be that low, but I read another post where they thought the dealer may not have topped off after adding the loader. It was new and I think over a gallon low. I need to get under the machine and see how they did adding the diverter valve etc. It's hard to get good help anymore, I'd rather do it myself, at least i know it's right.
Oh yeah, asked them to make sure the tires were inflated properly, they were not. I'm not even sure they prepped the thing! I noticed in the back of the manual a prep checklist, nothing checked however. Not to say they didn't do anything, but they should fill that out check list so we know what they have done. I work in the RV business and if an RV is prepped, there is always a checklist filled out.
Steve
/ New 2305! I'm an idiot... #95
If you follow the manual instructions exactly you won't end up with a correctly adjusted deck height, but you will end up with a level deck. There's no excuse for the front-rear imbalance. Good news - now that it's adjusted properly, you won't need to fiddle with it again even if the deck goes on and off 100 times.
Adding both the independent lift and diverter valve adds enough extra volume in the hydraulic system to drop the level below the sight glass, esp if it was already at 1/2 or lower. I think someone posted once that it's about 10 oz from bottom of the sight glass to the top. Yes, they should have topped it off but it's possible you're a hair low, not a gallon low.
Based on everything you've found I think it's reasonable for you to ask for a full checkout again, at YOUR place with you present. Considering that you've examined 3 items on the checklist and found 3 items not performed properly (tire pressure, trans level, deck level), you deserve a full checkout again. I don't see why you should lose more tractor time (2 days to reset the deck?) for what is a REALLY basic failure to prep for delivery.
The deck was a fairly easy job for not having done it before. Does the 4 1/2" height sound about right? That's in the locked position. I adjusted the clearance between the arm & stop first then adjusted everything else from there. I didn't think about the ind lift and diverter valve dropping the fluid level. You are correct, may just be a little low, guess I will find out.
I sent an email to the dealership last night explaining the situation, haven't heard back yet. I'm not in the mood to call and rehash everything right now. I'm going to go through the checklist myself, I think that will cause me less aggravation. Besides, then I know if they've not done other things. I just don't trust people to do things as they should.
Steve
/ New 2305! I'm an idiot... #97
Yes, 4 1/2" sounds about as high as you'll get IIRC. I haven't measured mine, but there's a section of field I mow in locked position and the grass is definitely not over 5" after cutting. My lawn is very uneven (I think real estate agents call it "rolling" :laughing:) so I mow it all very high.
There's a little chart printed on the 62C deck for setting the anti-scalp wheels- I think 4 1/2" is the max shown, but I'm not positive.
(2) 6 LUG 5200Ib-74SC-93 HUB FACE AXLES (A60432)
(2) 6 LUG...
2012 TROXELL 130 BBL STEEL (A58214)
2012 TROXELL 130...
2021 Kubota SVL75-2 Track Loader (A61306)
2021 Kubota...
2014 International WorkStar 7300 4x4 Altec AA55E 55ft. Material Handling Bucket Truck (A60460)
2014 International...
2022 Dodge Ram 4500 Miller 8,000lbs Wrecker Tow Truck (A59230)
2022 Dodge Ram...
2018 VOLVO VNL TANDEM AXLE DAY CAB (A59905)
2018 VOLVO VNL...
