OP
Rdrcr
Platinum Member
- Joined
- Feb 25, 2021
- Messages
- 837
- Location
- WA
- Tractor
- Kubota L2501 HST 4WD w/ S2T Turbo Kit = 35 PTO HP (Current), Cub Cadet Pro Z 560 S KW (Current), B2601 Kubota (Sold), E170 John Deere (Sold)
Thanks for your opinions Rdrcr. I consider an L2501 too, but I was always wondering if I'd like the FEL lever placement. I like my B with it beside me because I run big loaders at work and am used to the controls being close to me. (though now they are no longer joysticks, all fingertip control) But I wasn't sure if I'd like that stanchion mounted control lever. But good to hear it is smooth and well controlled.
The one comment that does concern me though is the drive power up hills. I realize the L is heavier than my B but that is something that is important to me. I carry a lot of material up hills in my yard maintaining my bush road. I've already hauled 330 metric tonne of pit run gravel up my hills with my B and it does it no problem in medium range. It even pulls my 60 inch Land Pride box blade up the hills in medium. Got the rear blade on in these pics.
Not sure if you hills are steeper than mine? Pictures don't really show it accurately.
That is a good looking tractor you got there though.
I too was concerned about the joystick placement comparing it to my B2601 (which is also right by the seat and comfortable to reach). But, the joystick on the L2501 hasn't been an issue and is surprisingly comfortable to use. I moved dirt for over 3 hours yesterday with the tractor. Not once did my arm feel fatigued. I prefer the joystick to be closer, but, the L2501 placement hasn't been an issue.
My L2501 has loaded tires, so it is heavy. I wanted the extra weight for stability on the hills on my property. It has worked out surprisingly well. I was making some turns on the hills yesterday and the tractor didn't feel "tippy" at all. That said, my main hill appears steeper than yours. I'll try to get some pics as an illustration. Although, I'm happy to report that yesterday, I was able to move up and down the hill in medium gear @ 1,800-1900 RPM. Why the change? I had buckets full of dirt, rather than an overloaded bucket full of wet logs. So, the uphill power isn't as bad I as I originally thought.
Definitely a good tractor, pretty much perfect for me. But, it does have it's limitations.
Mike
