New 1920 Owner
/ New 1920 Owner #11
I figured they'd all stay up if everything was working properly. Does the same hold true for the 3 point?
My experience is that the HPL valve and cylinder seal for the 3PH are much better than the cylinder seals and joystick valves for FELs. I would expect your 3PH to drop only slightly overnight under load, maybe an inch or two at most. A local Case/Farmall tractor sales lot put a round bale on a 3PH spear and left it lifted and holding for a couple of weeks. In the same time, an empty FEL bucket was lifted high and drooped within a few days. There seems to be a big difference in the tolerances on these systems. If your 3PH leaks down badly, it will "hiccup" as the HPL valve's position control will sense the change and correct it.
/ New 1920 Owner
Interesting. Thanks for the info!
2015 Nissan Altima Sedan (A59231)
2015 Nissan Altima...
John Deere 6110M (A53317)
John Deere 6110M...
2024 DEVELON DL250-7 WHEEL LOADER (A59823)
2024 DEVELON...
2015 JOHN DEERE 35G EXCAVATOR (A52707)
2015 JOHN DEERE...
2005 Ford F-450 Dump Truck, VIN # 1FDXF46P65EB16866 (A61165)
2005 Ford F-450...
200 Gallon Tank (A57148)
200 Gallon Tank...
