Never Seen Anything Like This...
/ Never Seen Anything Like This... #1
AL_Josh
Mobile, Alabama
Cub LT 1046, 2000 Honda Rancher, 2004 Carolina Skiff
Never seen anything attached like this to a backhoe. I have seen them attached to swampbuggy things. They have been in the area trimming limbs along powerlines for a couple of weeks. Though I would just post a few pictures.
/ Never Seen Anything Like This... #2
They do something similar around here using a boom pole. These pictures you posted look like some really bizarre fabrication though! Is that pole made of pvc?
/ Never Seen Anything Like This... #4
yes its a saw blade they are cutting the branches around the hydro lines
/ Never Seen Anything Like This... #5
Weedeater on steroids with a rotary brush/branch blade? Doubt it is PVC, most likley spiral wound fiberglass like a fishing rod. Large diameter for rigidity and not too much weight. Non-conductive for working around the lines.
/ Never Seen Anything Like This... #6
Morning Al.
Interesting,bet the operator one of the best around...must be they don't cut big branches of sort,for the Cat cab has no heavy metal extra protection.
/ Never Seen Anything Like This... #8
It took a little searching from here
Trim All Equipment Company’s saw blade mounts to a standard backhoe. The 24-inch circular saw blade sits on the end of a telescopic fiberglass boom which reaches heights of 55 feet. To mount, remove two pins that secure the digging stage of the boom, reinstall the pins in the bracket of the Trim All, and connect the hydraulic couplers. The controls are operated just as the backhoe controls work to swing, raise, and extend the boom. A valve engages and disengages a hydraulic motor that rotates the blade. The saw cuts limbs up to 10 inches in diameter quickly and cleanly.
/ Never Seen Anything Like This... #9
This last year the power company came through my area trimming back trees with something similar. The one here was an articulated machine with tires about 6’ tall and a boom with blade that reached over 80’. Wish I had a photo. This thing was driving through ditches that would have been hard on an ATV.
MarkV
/ Never Seen Anything Like This... #10
Probably fiberglass (or PVC would work) with hydralic lines so if he hits a power line at least the tractor won't light up...
/ Never Seen Anything Like This... #11
God forbid they should take the time to prune the branches the right way. Just cut them off without any concern about the health of the tree.
/ Never Seen Anything Like This... #12
That is interesting, not something I'd want to be at the controls of for sure! I once saw a powerline timmer dangling from a helicopter. It had several circular blades in a long contraption. Another thing I would not want to be operating.
/ Never Seen Anything Like This... #13
Markv,
I wonder if that was the same guy that trimmed the powerline on my parent's property here in MS, said he had came all the way from Georgia in that contraption trimming right of way.
/ Never Seen Anything Like This... #14
MLinOleMiss said:
Markv,
Could be. I talked to the guys a few minutes when it looked like that beast was going to come on the turf grass I planted on the power line. They were doing contract work for Ga. Power so I am sure they must travel a lot. It was obviously an expensive specialty machine so you have to keep it working.
MarkV
2022 Bautista Welding and Custom 40ft. 10 Ton T/A Gooseneck Flatbed Trailer (A61573)
2022 Bautista...
Hyundai 250 LC-7 (A64119)
Hyundai 250 LC-7...
Unverferth 330 (A64119)
Unverferth 330...
UNUSED WOLVERINE HYD MINI AUGER (A64281)
UNUSED WOLVERINE...
2019 BOBCAT E45 EXCAVATOR (A63276)
2019 BOBCAT E45...
2019 UTILITY VS2DX 53' X 102" T/A VAN TRAILER (A59912)
2019 UTILITY VS2DX...
