never removed 1464 fel, want to now
   / never removed 1464 fel, want to now #1
GaryS
franklin park, pa
Kubota L3901 & LA525
I'm going to start cutting my yard with my new RFM. I've had a 1428v for 3 years and have never had the need to take off the FEL. I'd like to take it off to reduce the weight on the yard and to give me a bit more maneuverability. The manual makes it look easy - but it also made changing the engine oil filter look easy too and t was a bear.
Any gotcha's that I should be aware of when removing or re-attaching? Is this a quick operation or should I just leave the darn thing attached?
   / never removed 1464 fel, want to now #2
I have a MF 1445 with a 1040 loader and it comes off pretty easy. I have taken it off several times, usually when I service the tractor to be able to see things better and to put my snow blower on. I am not sure if yours comes off the same way mine does, but mine will just "roll off" with the help of hydraulics, and the same when putting back on. I put a piece of plywood on the ground so when the noise hits its not buried in the dirt. The only thing I am carefully of when taking of and reinstalling is to watch to make sure I am centered, looks like if your not carefully you could hit the hood if you get off center too much. Hope this helps.
Dennis
   / never removed 1464 fel, want to now #3
I know I am comparing apples to oranges here but the loader on the MF2300 is supper easy... raise the bucket, set the legs, lower bucket until relief for the 2 pins, pull the pins and continue rolling bucket until the loader walks out of its mount cradle, unhook hydro connects and back away 3 mins tops.. hope it helps :)
thanks for the replies. I cut today with the loader attached but I really got to take it off. I whapped a few trees and feared hitting something worse. I didnt have the time to try taking it off today - I'll give it a shot this week.
   / never removed 1464 fel, want to now #5
did you ever figure out the proper way to remove your loader
2003 Pierce Tilt Cab Pumper Fire Truck (A50323)
2003 Pierce Tilt...
2013 FREIGHTLINER BUSINESS CLASS M2 VACUUM TRUCK (A51406)
2013 FREIGHTLINER...
378751 (A51573)
378751 (A51573)
2015 FREIGHTLINER SPRINTER VAN (A52576)
2015 FREIGHTLINER...
2015 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2015 Ford F-150...
2019 Chevrolet Tahoe SUV (A50324)
2019 Chevrolet...
