never owned a tractor need help
   / never owned a tractor need help #1
TCarson17
I have never owned and tractor before but have always wanted one. I have been looking around and there are some many choices. I like the Kubota and have looked at the B3300 and the l2800 up to L3700. I will be using to maintain about 2 acres of woods that is my yard no finish mowing. I also will use it at the hunting club to plant 10 food plots from .25 acre to 1 acre in size. Would like to be able to clear some roadsin the cutover and possibly make some of my food plots bigger. I know I want 4 x 4 and a bucket. I will also need a brush cutter and disc or tiller (which do yall recommend) and probably a box blade for my driveway. I guess the big thing is what size tractor and what kind of tires. This is a large investment and I don't want to over buy but I dont want to wish i had more later.
Thanks for your help
   / never owned a tractor need help #2
For the 2 acres and the food plots something like a BX could be a good choice.
For clearing roads, the bigger the better.
You want R1 or R4 tires for this work. The only thing turf tires are good for is finish mowing.
   / never owned a tractor need help #3
Unless you just want to sit higher off the ground the B will do all you've listed. Get the boxblade and tiller. Use either one for counter weight when using the FEL. Get HST if your going to be using FEL much. I like R4 (I4) tires but the ags probably give better traction if you need it but probably won't. If driving on pavement much the ags will wear quicker than R4's.
   / never owned a tractor need help #4
I believe you'll be happy with your Kubota - regardless of which one you choose. What do you mean by 'maintain two acres of woods'?
   / never owned a tractor need help #5
Without knowing your land and specific needs, I would strongly consider the Bxx30 Series. I don't really see anything to indicate the need for an L even though I really like them.
   / never owned a tractor need help #6
There will be a learning curve.
Are the food plots cleared already?
If you are calling this a large investment there's a tradeoff in wrenching skills versus cost. For the work you've listed I think my little B7610 would work. However a good used B7800 would probably be more appropriate. Barlows has a couple in the 12K price range,and they deliver all over.
Tires - try to get Ag.
   / never owned a tractor need help #7
Don't think you can go wrong with a Kubota...
I've had my BX23 TLB and accomplished a lot with it...
One thing to consider is how you will transport should the need arise...
Heavier Equipment and implements dictates larger trailer and tow vehicle...
Thanks for the advice. The 2 acres would is essentially my yard and its more just trees than woods. Just some undergrowth to maintain and knock down ususally have to ge some to bush hog it a few times a year. The foods plots are established but I would,like to make some bigger. How long it takes its really not a big deal as the hunting proerty is next to the house. As far as transport I have access to a 16ft tandem axle trailer with tralier breaks and two 3500lb axles that i would use.
   / never owned a tractor need help #9
Yes, a 30 series B or small L series will suit you and your needs just fine. You won't find a huge price difference in the various models. But.....
When push comes to shove, however, and there is a $2000 difference between the two finalists? Do remember that a tractor is just an engine on wheels without the proper attachments. You must reserve some spending for the right equipment. Spend the last few grand on implements, not more horsepower. These diesels pull and horsepower is seldom used up, but traction is.
Since 90% of your work is in the dirt, consider going with R1-Ags, unless you are under stating your loader work time. Enjoy the adventure and be safe.
There is indeed a learning curve.
   / never owned a tractor need help #10
I have a B2620 and from what you described this tractor could handle those tasks. It would fit on your trailer nicely, and the weight isn't much. I would recommend the R-4's, they get good traction, and when the ground is muddy or soft they won't leave deep tread ruts. Someone with the AG tires can talk this but my R-4's can fling enough mud around I can imagine the AG tires would fling more. Be sure to get the tires filled with the antifreeze solution though which ever type you decide to get.
Good Luck with what ever you get, I don't think you will be disappointed.
2020 FREIGHTLINER CASCADIA SLEEPER TRUCK (A59905)
2020 FREIGHTLINER...
2016 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2016 Ford F-150...
2009 Bruton T/A Enclosed Livestock Trailer (A55973)
2009 Bruton T/A...
2025 CFG Industrial NT20-CZ Mini Excavator (A59228)
2025 CFG...
2025 GPS Trailer (A56858)
2025 GPS Trailer...
2013 Ford F-450 Dump Truck (A59230)
2013 Ford F-450...
