3-Point Hitch Never noticed smaller 3pt
   / Never noticed smaller 3pt #31
Slippy said:
BobG, I think we talked about this before, but I don't take the lift arms off when I put my bh on. I take the side sway adjuster arms off. QUOTE]
Glad you got the sleeve out. If I remember correctly you use the tractor hyds. for the BH? I have the PTO pump and the res. is about 12 gallons (read as Big). It takes up a bunch of space right in the middle. I leave the stabilizers on the underside of the tractor -- and let that part hang down as it doesn't hit anything and is about 6 inches from the ground. The 3pt arm brackets is where they come loose and I leave the upper part of the 3pt hanging down out of the way. Takes about 10 minutes off and 15minutes on as I have to hold them up and get the pin thru at the same time (buggers are heavy). Glad you got it squared away. BobG in VA
Right, I forgot about your tank. So sorry. Yea, glad to have such a little thing out of the way that was frustrating me.
2008 DOOSAN G25 GENERATOR (A55745)
2008 DOOSAN G25...
WB 36" PIN ON DITCHER BUCKET (A52707)
WB 36" PIN ON...
2017 KUBOTA SVL75-2 SKID STEER (A52707)
2017 KUBOTA...
2012 PETERBILT 367 (A55745)
2012 PETERBILT 367...
2023 Stryker GN3614 36ft. 5 Ton T/A Gooseneck Flatbed Equipment Trailer (A51691)
2023 Stryker...
2015 Chevrolet 1500 Silverado Pickup Truck (A55852)
2015 Chevrolet...
