aspg4
Will a bad neutral switch on MF 135 cause motor to not turn over.
Yes more than likely. Have You tried starting it with the clutch pedal depressed? If it does start; Or turns over with the clutch pedal depressed; That would tell you the the neutral switch is either bad or it is in a stuck in position on the shifter rod. Also there could be a bad connection on the wiring.Will a bad neutral switch on MF 135 cause motor to not turn over.
Should be able to remove the wires from the switch, touch firmly together and see if the starter will activate, or at least click.
I do have to ask if this tractor is new to you. On my 35 I thought I had the same problem, so when all else failed I got the Operators manual out. On the 35 the high-low shifter must be in neutral, not the main transmission as most all other brands. I went back out thinking it surely couldn't be that simple. Placed the high-low shifter in neutral, and it spun over like a champ. Lesson learned.
Thanks for the follow up; I'm glad You found the problem. That's what I like about older tractors; It's usually something simple; & most of the time a simple fix.Found the trouble. It is a bad ignition switch. Took wire off the switch and touched the wire to battery and tractor started right up.
