Neutral safety switch issue
   / Neutral safety switch issue #1
pekabu
Platinum Member
NH
TC24D
I am having an issue with my TC24d. I live in NH, and it's been really cold, and when she sits for a while like 24hours I have to move the range selecter back and forth a lot, then I have to sort of fine tune where I put it so I can start the tractor. Once it warms up, this is not an issue. It looks like the switch is based on a rocker arrangement with the lever. It also appears there is some adjustment to the lever. The problem is though when I first jump on it, there is no response from the starter until I move the lever.
Thanks /forums/images/graemlins/confused.gif
   / Neutral safety switch issue #2
I had the same issue on my TC18. Assuming your 24 is the same (should be close) you can adjust the switch. take the wheel off & watch the switch as you move the lever. You want the switch engaged at the max when the lever is in "N". If I'm remembering right, with a wrench or two, you can thread the switch in or out, or slide it along a slot.
   / Neutral safety switch issue #3
I had the same issue with my TC18. Adjust the switch with a cuple small wrenches, and you'll be good to go. Took about 15 min.
Dave
2018 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A52576)
2018 FREIGHTLINER...
2017 Chevrolet Express Box Van, VIN # 1GB0GRFF9H1305955 (A51572)
2017 Chevrolet...
2012 FORD E-SERIES 11 PASSENGER VAN (A52472)
2012 FORD E-SERIES...
HYSTER H50FT FORKLIFT (A52472)
HYSTER H50FT...
2024 BCL Fabrication Landscape Dump Trailer - Heavy-Duty Utility Trailer for Mulch Debris Hauling (A52748)
2024 BCL...
2021 GMC SIERRA CREW CAB TRUCK (A51406)
2021 GMC SIERRA...
