Neutral safety switch issue
   / Neutral safety switch issue #1
pekabu
Platinum Member
NH
TC24D
I am having an issue with my TC24d. I live in NH, and it's been really cold, and when she sits for a while like 24hours I have to move the range selecter back and forth a lot, then I have to sort of fine tune where I put it so I can start the tractor. Once it warms up, this is not an issue. It looks like the switch is based on a rocker arrangement with the lever. It also appears there is some adjustment to the lever. The problem is though when I first jump on it, there is no response from the starter until I move the lever.
Thanks /forums/images/graemlins/confused.gif
   / Neutral safety switch issue #2
I had the same issue on my TC18. Assuming your 24 is the same (should be close) you can adjust the switch. take the wheel off & watch the switch as you move the lever. You want the switch engaged at the max when the lever is in "N". If I'm remembering right, with a wrench or two, you can thread the switch in or out, or slide it along a slot.
   / Neutral safety switch issue #3
I had the same issue with my TC18. Adjust the switch with a cuple small wrenches, and you'll be good to go. Took about 15 min.
Dave
2025 12V Diesel Pump and Hose (A50324)
2025 12V Diesel...
2009 IC Corporation PB105 Passenger Bus (A51692)
2009 IC...
2016 Kia Optima Sedan (A48082)
2016 Kia Optima...
7021 (A50322)
7021 (A50322)
