Nelson stud welder
/ Nelson stud welder #1
Cord
Richfield, Wi
Resident Architect
Due to a stupid mistake I managed to shear off a hydraulic pump shaft. The pump isn't horribly expensive, but the broken piece is jammed inside a drive pump that's worth $4000. I can't grab the piece with a vice grips so I need to weld something on that I can grab. A nut is the first option, but I'm worrying about splatter contaminating the drive pump. There is a Nelson 450 stud welder for sale about 4 hours from me. I think this is a great solution and will give me a tool that might have a residential use for some other project. I thought about a body stud welder, but I don't know if the pins are strong enough. Does anyone have experience with stud welders? When using threaded studs, 1/2" and under, are the ceramic cups needed?
/ Nelson stud welder #2
I have only used 3/4” or larger studs. The ceramic holder contains the molten weld until it cool. We can have splatter when welding studs
/ Nelson stud welder #3
I have never used a stud welder but all the stud welds I have inspected had splatter
/ Nelson stud welder #4
Maybe use a short pipe that will fit in the hole. Then use a 3/32 7018 welding rod inside the pipe like this -
/ Nelson stud welder #5
i would recommend a machine shop tig weld the broke end and extract the broken part. no splatter, heat eases the removal. tig is the way to go.
/ Nelson stud welder #6
How are you going to ground the broken stud without going thru the drive gears or bearings?
As was said, go with a short piece of pipe, you can use that as your ground as it will be in direct contact with the broken shaft and the pipe protects the surrounding bore from stray strikes or spatter..........Mike
JOHN DEERE 6R RIPPER / LISTER BEDDERS (A63745)
JOHN DEERE 6R...
2018 Chevrolet Trax SUV (A59231)
2018 Chevrolet...
2003 International 4300 Flatbed Dump (A62613)
2003 International...
1989 GMC 6000 SCHOOL BUS (A63290)
1989 GMC 6000...
10' BOX BLADE, 3PT (A63290)
10' BOX BLADE, 3PT...
1999 CHEVROLET 2500 SERVICE TRUCK (A63290)
1999 CHEVROLET...
