Neighbor has elected to damage over 20 trees
   / Neighbor has elected to damage over 20 trees #401
Sometimes a new easement or ROW over an existing road is defined or surveyed so many feet on either side of traveled center line. Many times an easement or ROW is described or shown on a plan before the road is built and as others have suggested , who knows where the road is actually located until surveyed. Could be on the ROW totally, partly or not at all.
Al
   / Neighbor has elected to damage over 20 trees #402
My rancher friend has deeded right to pass for moving livestock over neighboring land... the Deed goes back to the mid 1800's.
The park district immediately blocked access when it acquired the neighboring land.
It has been a battle going on almost 20 years... the rancher removes the impediment and has been cited numerous times... each time he wins in court.
The latest round from the District is to seize by immanent domain my friends property...
A person may have the law and every right in the book but still not prevail...
   / Neighbor has elected to damage over 20 trees #403
In my smallish city of 50,000 the center of the street is usually the property boundary or used for measuring purpose. However its quite common for it to not be the center of the street for a variety of reasons. Same for county rural roads due to their avoiding rock outcroppings, erosion areas, creeks, etc.
One last time guys ! The ROW is established from the center of the road period. The Plat survey shows the 50' ROW marked going down the center of the road...25' each side. Basically the ROW follows the center of road, where ever it meanders !! The road was built in 1992. It is what it is....not going to stir up a hornets nest over it ! This whole thread has been a great source of input on what you need to do if and when you buy property..!!
   / Neighbor has elected to damage over 20 trees #405
Sorry for the last post. I was not referring to your situation. Just general discussion. Maybe we should have a new thread about ROW's only.
   / Neighbor has elected to damage over 20 trees #406
That’s all fine and dandy. Markers placed so boundaries are known. Now the concern would be to keep the road where it is. Not have maintence or modifications of the road allowing those right of ways boundary’s to come into question.
   / Neighbor has elected to damage over 20 trees #407
Thatç—´ all fine and dandy. Markers placed so boundaries are known. Now the concern would be to keep the road where it is. Not have maintence or modifications of the road allowing those right of ways boundaryç—´ to come into question.
And that is a real possibility over the years. Happened locally near me with the original route of a township road.
Over the years the township road crew gradually reduced some of the sharp turns in the road by cutting and straightening the roadway. Well, while the property survey co-ordinances never change, they are no longer aligned with the center of the road. There were no concerns with the current land owners at the time. But as property is be bought and sold to newcomers and new surveys are being conducted, disputes are arising. While nobody has actually gained or lost any actual acreage, some are claiming land on both sides of the road, while another is complaining they don't have the road frontage they thought they had.
   / Neighbor has elected to damage over 20 trees #408
Right, it is just the way it goes as roads get maintained, straightened, etc. public or private. The whole center of ROW is the center of the road, is nice to believe, it is just not reality. A few feet is not worth losing sleep over or worth sending your hard earned money to an attorney over. It just is not except maybe in some very rare situations.
   / Neighbor has elected to damage over 20 trees #409
Yep... my brother owns to the middle of the "County" road... the reality is he owns the entire road as it was realigned in the 1930's
It has made for some interesting discussions... the property had been in the same family since 1860 prior... especially when his surveyor put stakes in the across the road neighbors lawns!
It simply was not that exact as to following the documentation when the county paved it... now it is a heavily used county road.
Brother had an event at his property... and over flow parking was on the shoulder... the sheriff came out and said the county road couldn't be used for parking...
My brother said he would make sure the guest parked on his property... but the entire section of road is his property...
They had a good chuckle and that was it.
   / Neighbor has elected to damage over 20 trees #410
That's the way they do ROW's here too. From the center of the road however ever the road my go.
I had some property I own surveyed that had never had a survey. The survey man went to the center of the dirt road and set up his device. He then set pins for the front corners of the property and worked from those pins
2018 Allmand Light Tower (RUNS AND WORKS) (A50774)
2018 Allmand Light...
2014 CATERPILLAR TL943C TELESCOPIC FORKLIFT (A51242)
2014 CATERPILLAR...
UNUSED KJ 11' X 19' SINGLE STEEL CARPORT (A51244)
UNUSED KJ 11' X...
2009 CASE IH3406 - 6R36" CORN HEAD (A51243)
2009 CASE IH3406 -...
2019 John Deere 410E 40 Ton Articulated Off-Road T/A Dump Truck (A50322)
2019 John Deere...
2012 Ford F-250 Crew Cab Pickup Truck (A50323)
2012 Ford F-250...
