Needing 50 amp plugs for generator
   / Needing 50 amp plugs for generator #1
bdog
Elite Member
Texas
John Deere 6130M
I need some 50 amp plugs to use for my generator. It has no plugs just lugs as it is a big diesel unit. I need some type of weatherproof female connector to mount on the generator, in my shop, and a weatherproof male to mount on my work trailer. The cord will have a male and a female end.
I need something quaility as this will be connected and disconnected weekly and will see very near the 50 amp load.
Weather proof female connectors in a box are pretty easy to find but I am not finding much for male connectors in a box.
   / Needing 50 amp plugs for generator #2
They are a common item. I just saw them yesterday at HD. Some RV type hookups can go up this high but it’s more common to have a screw together type.
   / Needing 50 amp plugs for generator #3
Not sure what type you want to do but this website should point you in the right direction-
5 Amp RV Locking Power Cordset
They have several other items depending on your needs.
   / Needing 50 amp plugs for generator #4
What you are looking for is a NEMA 14-50P Inlet box. That is a Twist lock connection with 4 prongs and if you get a waterproof inlet box it is waterproof as well.
On your shop you will need a female waterproof Outlet that way you can have two Hots a neutral and a ground going out to your trailer.
Then on your generator you will need the female version of that with the neutral and the ground tied together inside the plug.
Aaron Z
   / Needing 50 amp plugs for generator #5
Reliance Controls PB50 or PBN50.
Or a PK50 if you want to flush mount it into the side of the trailer: Robot Check
Aaron Z
   / Needing 50 amp plugs for generator #6
This is the way to go. I have never installed the PBN50 but have put in many PB30 and PB50 this is how we install almost all non automatic generator setups. Just a warning the PB50 is tight as far as wire space is concerned, I had never seen a PBN and I might give that a try on the next generator. These are for 120/250vac single phase, you didn't say the voltage but if the generator is 3 phase or 277/480vac (also 3 phase) then this is not the plug you want. I only ask because if you are regularly using a generator of this size it could be you have tools that require this and not because the shop has no utility power.
PB5 Transfer Switch Accessory - Reliance Controls Corporation
(3) CAT PALLET JACKS (A54756)
(3) CAT PALLET...
UNDERCARRIAGE ROLLERS (A53843)
UNDERCARRIAGE...
2013 PETERBILT 365 T/A DUMP TRUCK (A51406)
2013 PETERBILT 365...
2015 Hyundai Sonata Hybrid Sedan (A53424)
2015 Hyundai...
1992 Ford F-150 Pickup Truck, VIN # 1FTDF15Y3NNB06697 (A51572)
1992 Ford F-150...
2012 Jeep Liberty SUV (A53424)
2012 Jeep Liberty...
