NeedHelp !! Case ih 235H...lift and not going up
   / NeedHelp !! Case ih 235H...lift and not going up #1
ken338
1988 Case IH 235H
like i said, the lift arms dont go up they dropped right to the ground... previously when the blower was up it never stayed up
   / NeedHelp !! Case ih 235H...lift and not going up #2
I have had this same issue on 2 different Mitsubishi made tractors so I sympathize. It could be several things, I will put them in order of likelyhood.( in my opinion anyway)
*The relief valve for your 3 point hitch hydraulics could be stuck open ( I've had this happen several times).
* The orings on the 3 point hitch piston need replaced.
*The 3 point hitch control valve or the control linkage is the culprit.
Parts diagrams can be seen here Case (235) - CASE IH TRACTOR (1/86-12/88) Parts Diagrams Do you have a service manual?
hey Darryl,
thank you ....
few questions...
1. how do i unstuck the relief valve
2. the orings... do i have to take everything a part and should i replace all orings in there
3. any idea or solutions of what i should do as for the control valve or the control linkage...
4. where is the control valve ?
Ken...
   / NeedHelp !! Case ih 235H...lift and not going up #4
I want to preface my answeres by saying I have never worked on this model machine but pretty sure it has some similarity to my current Mitsubishi tractor. I also am assuming you have checked hydraulic fluid level and cleaned any hydraulic screens or filters prior to posting here.
I also should have included two other possible causes....you could have a bad pump or you could have condensation in your hydraulic fluid that has frozen and is clogging a screen or filter. Have you checked the screen/strainer or hydraulic filter? If not, did your issue begin to happen during freezing temps after the tractor had been sitting in freezing temps?
OK, now to answer your questions:
1. Relief valves usually stick open because of a piece of debris. The valve has to be disassembled and cleaned. I am not sure if your relief valve is in the control valve or on the left side of the hydraulic housing like on my tractor.
2. The piston orings should be able to be replaced by removing the lift cylinder head and pulling the piston out. The head is the plate that holds the flow control valve ( speed control) for the 3 point hitch ( is located below the seat/ between your legs while seated).
3. I would start with the linkage and make certain everything moves or is attached like it should. The control valve would need to be disassembled, cleaned and any torn/worn orings replaced.
4. I feel pretty comfortable saying it will be located under the hydraulic housing cover ( the large case that holds the flow control valve on the front/ rock shaft for 3 point lift) on the rear.
If you don't have any manuals, look at the parts diagrams I linked in my first post. I would also highly recommend buying a service manual!!! An absolute bargain for $20 and the best money you will ever spend on your tractor! Service Manual - Ih-s-235 International Harvester Case IH 235 | eBay
i just ordered the book you link in the previous post and will be checking lot of thing and taking pictures this weekend when i am off ... thanks and ill keep you posted
Husqvarna Riding Mower (A56857)
Husqvarna Riding...
2020 DRAGON ESP...
2023 FORD F750 CAB & CHASSIS (A57880)
2023 FORD F750 CAB...
2012 Vantage P-42-1000 42ft. T/A Dry Bulk Pneumatic Tank Trailer (A55973)
2012 Vantage...
Stanley Hydraulic power pack (A56435)
Stanley Hydraulic...
RAKE ATTACHMENT FOR MINI EXCAVATOR (A58214)
RAKE ATTACHMENT...
