Need wiring harness 1973 Ford 2000 3cyl gas
   / Need wiring harness 1973 Ford 2000 3cyl gas #1
trucol
Shelby, Mississippi
I have a 1973 Ford 2000 3cylinder gas burner. I had to replace the gas tank, and found that the wiring harness was very brittle. I believe a wire (or two) broke, and now it won't start, or instrument cluster won't come on. I'm trying to find a wiring harness for my tractor. The part # that the parts diagram shows, is for a diesel only. I got someone at a dealership to look it up (#88615838). It was over $200. When I googled it, it didn't appear to be what I need. That is a lot of money to gamble, if it's not what I need.
Can anyone please help me with the correct part number, and possibly where I might get one for less money. I need the harness for the instrument cluster, ignition switch, solenoid, and generator. It's a two part harness.
Any help would be greatly appreciated!
T.C.
   / Need wiring harness 1973 Ford 2000 3cyl gas #3
I typed Ford 2000 wiring harness into ebay and got a lot of hits. You might try that and see if you can visually match it up.
   / Need wiring harness 1973 Ford 2000 3cyl gas #4
Find a Sparex dealer.
Sparex parts are readily available on ebay. I just bought half a dozen for my newly acquired 3910. Ebay sellers are real good (per my successful purchases) on identifying parts to fit certain tractors.
2000 Trail King TK70SA-48.2 T/A 43 Ton Hydraulic Slide Axle Step Deck Trailer (A52377)
2000 Trail King...
2022 FORD F-150 LARIAT CREW CAB TRUCK (A51406)
2022 FORD F-150...
UNUSED INDUSTRIAS AMERICA SK72 72" HYD BRUSH CUTTE (A51247)
UNUSED INDUSTRIAS...
2019 HINO 268 26FT BOX TRUCK (A53426)
2019 HINO 268 26FT...
UNUSED JCT 72" HD BRUSH CUTTER (A51248)
UNUSED JCT 72" HD...
