Chipper Need Vacuum/Shredder, but not chipper.
   / Need Vacuum/Shredder, but not chipper. #11
Keith,
When you get the Cyclone info they have references provided - looks good from what I have seen. It was advertised on one of the garden shows and we called and they sent a nice package with video.
I got the package two month ago when the leaves were still on the ground and then tax time came & needed to send Unc Sam some $ so had to put it off for a bit. Cleaned them up by hand again this year and when I'm doing it I think gee, wouldn't it be nice to have a vac system, then the job is done (in two weekends) and we wait for the fall.
I compost everything here by raking the leaves into large piles then mowing over them back and forth to shred them up - this creates huge reduction in volume to drag to the compost pile as well they break down faster when mixed with some dirt and 10-10-10 fertilizer.
When you reduce leaves they get heavy on a plastic tarp, so I wove a rope through the grommets then bring it around the base of my seat on the Cub Cadet and drag them to the pile - (about 400' to where I compost) Saves the back and legs.
The tarps only last 1-2 seasons since rocks and stuff tear them up, but their cheap enuf.
Carl
   / Need Vacuum/Shredder, but not chipper. #12
Chris,
Youre right the radial fan will not chew up the leaves as that is the mower's task, and since the mower is attached to the vac it's a matter of when you start the vac. . As I posted a note regarding how I handle leaves, this is one option, shred them first then vac them up
Carl
Carl
   / Need Vacuum/Shredder, but not chipper. #13
Carl
Thanks for the reply and the other tips.
Sounds like you love leaf season as much as I do!
Guess it's not as bad if you have the right power equipment.
Keith
   / Need Vacuum/Shredder, but not chipper. #14
Keith:
I ended up buying the larger Cyclone Rake a year ago; at the time, no one here seemed to have much experience with them. I've been quite satisfied with it (my wife feels it's the best piece of equipment we've ever bought). Various details:
We've ended up switching to a John Deere GT235 garden tractor for mowing, and use the Cyclone Rake attached to it, rather than to our compact Ford 1220. When I first talked to the Cyclone Rake salesperson, they didn't think it would work with a compact tractor; in fact, they didn't know what "compact tractors" or "3-point hitches" were. While picking the unit up at the factory, I discovered they do have an adapter which would mount it to (some) drawbars; ask for a "Kubota adapter." The rigid attachment of the Cyclone Rake to the rear of the tractor (as opposed to the single-point trailer hitch the Trak-Vac appeared to use) is one of the unit's biggest advantages; it greatly simplifies maneuvering when backing up, especially when dumping the unit.
We use the vacuum pickup hose (for planting beds and stone walls) roughly 50% of the time, and the mower deck attachment (for lawn areas) the other 50%. While you can collect some smaller sticks with the mower, they suggest not vacuuming sticks with the hose attachment. As noted in an earlier post, the Cyclone Rake has a heavy-duty plastic impeller, which will shred some items, but isn't going to do the work of a flail assembly. The mower attachment is very effective on thick lawn areas, but doesn't work as well on paved or other smooth surfaces, where leaves tend to blow out from the mower deck before the vacuum can capture them.
Several parts on our Cyclone Rake were damaged when we received it, but the factory was very responsive and sent replacements within 2-3 days.
You should note that the price starts climbing if you opt for the heavier duty hoses, as well as accessories like the vacuum pickup hose, exhaust discharge hose, hose carrier rack, etc. (in total, our unit ended up closer to $2000).
Feel free to email me if you need additional information. Overall, we've been happy with our Cyclone Rake and would buy it again.
Andy
   / Need Vacuum/Shredder, but not chipper. #15
Andy
Thanks for the info.
Went to a Kubota dealer Friday, one of our topics of discussion
was MCS. My main concerns are spring and fall clean ups.
I have a large White (I think) Oak tree in my front yard and several more on the property, last year they did a major accorn dump. I'm still going to have to work the front yard some more with a rake even after having a landscaper run over it with a Walker ZTR with a collection system.
The dealer explained that vaccum systems need air to flow UNDER the material they are trying to pick up.
Once the accorns become a little "seated" into the soil the only way to get them out is a rake. He took numerous implaments home to work his yard (he has the same kind of oak trees) and the implament that worked best was a seeder that had knife attachments on it used to slice the ground during the seeding process. The knifes would dislodge the accorns for easier pick-up by hand rake (did I say that nasty word!!!) or a MCS.
I did alot of research on the fourm this weekend and learned that quite a few people treat the leaves the same way I have over the last few years, mulch 'em into the lawn!!!
The Kubota MCS caught my interest because it is PTO driven. But considering my main use for it or any MCS was/is the accorns and they will most likely NOT pick them up I have decided to use that money towards a diffrent implament.
Lucky for me the Oak trees only do a major dump every few years.
Now it's back to thinking about which tractor to get and which method of snow removel will work best for me.....it never ends.
Keith
   / Need Vacuum/Shredder, but not chipper. #16
I don't know just what size you're looking for but Matthews Co. makes a really great unit that fits on the three point hitch of a tractor. It's really quite a unit that has hydraulic dump and holds a ton. If I can find a link for it I'll post it for you. If you want to see it go to the Outdoor power equipment show in Louisville this summer.
Their combination flail mower and hopper looks like it will do the job. I forsee throwing all the garden material to be composted onto the grass paths, and then driving down the aisles in the garden "flailing it up" into the hopper. I haven't bought any mowers yet, so I may get this unit to "kill two birds with one stone". Thanks for the link.
   / Need Vacuum/Shredder, but not chipper. #19
I've used a 5hp tow behind Trac-Vac (pulled with a Bolens rider lawnmower) for the past 15 years. It has been a life saver for fall cleanup. I compost all my leaves and grass clippings. I have a Ford 1220 with a FEL that I turn the compost pile with. I have been wanting to update the trac-vac and have been looking at the cyclonerake commercial. I first wanted to get a combination Vac-chipper but the more I thought about it...accidently suck up a rock and bend the impeller blade, then you have an expensive repair(it's happened). That's what I like about the cyclonerakes flexible impeller. Cyclonerake says their commercial model can be quite heavy to dump. Has this been your experience? How the cyclonerakes breaks down is good for storage but I wonder what the life expectancy is for the fabric trailer sides?
   / Need Vacuum/Shredder, but not chipper. #20
Doc;
If you get one post a note and let me know how it works. When I get my tractor I would like one for around the homestead. Thanks
2006 CATERPILLAR 304C (A58214)
2006 CATERPILLAR...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
CATERPILLAR 305 CR EXCAVATOR (A52709)
CATERPILLAR 305 CR...
2014 AMERITRAIL LAY FLAT HOSE TUGGER TRAILER (A58214)
2014 AMERITRAIL...
2006 Columbia Medical Transport Electric Utility Cart (A56859)
2006 Columbia...
International S1900 (A56436)
International...
