TexasDigger
Bronze Member
Technically I'm not brand new but have an urgent issue. See links below for the longer threads but in short: I made the mistake of not buying enough tractor & am about to trade up! I already have #s ready to close deal on either the Kiot RX6620 ROPS/PS or the NH WM 75 ROPS (same as Case IH Farmall 75A). I will be using my tractor for a LOT of loader work, clearing overgrown wooded property, grubbing & pulling trees, plowing, grading, occasional medium duty baling to stock up for winters. The loader seems like it may be a shortfall on the New Holland based on reviews of the Case 75A & the online specs. The NH & Case don't show anything bout breakout force and it's important that the loader be able to rip out at least 4-6" trees or almost pointless to even bother upgrading. You can't do any of this kind of testing on a "test drive". Experience on the Kioti RX7320 would also help, as is basicallythe same tractor but tuned up for 10 more hp (it's out of my price range so no need to discuss that - already over max budget on the 6620).
Does anyone have experience with both of these tractors to give any advice? Any help/experience appreciated.
Here's my other two replies/posts in more detail on same subject but I've gotten no feedback other than to "test drive" which still doesn't tell me about the loader REAL-WORLD power:
www.tractorbynet.com
LS XU6168 shuttle, KIOTI RX6620 Power Shuttle, other suggestions???
Ok I need some advice from someone with experience on both smaller and larger frame tractors. Sorry in advance if its a long post but lots to cover: I am 85 hours into my Kioti CK 3510 HST. I really do love this little workhorse, and if it could run a baler and lift a wet 5x5 hay bale without...
Buying Advice - Kubota M7060HDC vs NH Workmaster 75 vs Kioti RX7320
I have a 7320 and other than a bad o-ring on a remote and having to adjust the alternator belt no problems in 3 years and 400 hours. Recently upgraded to a 12' batwing mower and it pulled fine in the little bit that I have used it (used a neighbors 15' and it was a little much in heavy wet...
