Insurance Need Tractor Insurance Help
   / Need Tractor Insurance Help #11
My separate specific Kubota L-3130 Tractor policy costs me $53 per year from Farm Bureau, liability, theft, etc., it's all there.
   / Need Tractor Insurance Help #12
Is that Farm Bureau insurance available only in Florida? How do we find out about it?
Thanks
Andy
   / Need Tractor Insurance Help #13
I'd sure like to hear something about this farm bureau insurance myself.. I trailer mine to differnet properties quite often and would like to know more about possible insurance policies.
   / Need Tractor Insurance Help #14
Briarwood's response was a good one and one I would recommend following. I will add a few generalized details for those interested. I used to be an adjuster and am still in the business. Now for the disclaimer - all companies and all adjusters are different. I am not your adjuster and I am not working for your companies. These are simply guidelines for how, in my opinion, your claim should be handled if you have one.
Virtually all of you have what is known as an HO-3 policy if you own a home. The exceptions are the large national carriers like State Farm and Allstate, etc, although their policies often read substantially the same in many cases. I am not sure in this instance. There are basically two versions of the HO-3 in play right now, the 1991 edition and the 2000 edition. Most are still using 1991. Some might also have a 1998 version. If you have a version previous to 2000, look at the top of the second column on page three, it reads that motorizd land convenyences are covered if they are not subject to registration, and they are used to service your residence. This assumes you do not use the tractor in any way or at any time for any business purpose. It does not say that it has to be on your premises in order to be covered, just that it is used to service your residence. Your tractor is considered personal property, which means it is covered for the 16 named perils located on pages 8 and 9. If it is damaged by any of these these things, you should be covered. If you would like it to be covered on an all risk basis instead of just the named perils, you need to schedule the tractor on a special floater attached to your homeowners policy.
I mentioned the 2000 edition above. There is a significant change that affects your tractor, and it is done with one word. It states that the motorized land conveyence must be used SOLELY to service your property. In other words, if you ever use your tractor to mow the neighbor's yard while he's on vacation, or push back his snowbanks in the winter, you are forever precluded from coverage under your homeowners policy for that tractor. One word makes a big difference in coverage on the new policy.
This is just a basic generalized overview on how the coverages should work. Remember, if you ever use your tractor to make money, it is a business purpose and you are likely out of luck for coverage on a homeowner's policy. Finally, I am not an attorney and this is not legal advice. It is simply a generally accepted interpretation of the homeowner's policy based on my previous experience. Your mileage may vary.
Every situation is different and open to interpretation by those parties involved, and this discussion should and would have no bearing on a particluar claims scenario. I am not authorized, nor do I intend to be authorized to interpret any particular scenario on anyone's behalf. Sorry for all the disclaimer, but it's a litigious world we live in, and this is not an interpretation of your particular policy. Hope this wasn't too wordy and helps clear some confusion.
   / Need Tractor Insurance Help #15
</font><font color="blue" class="small">( I mentioned the 2000 edition above. There is a significant change that affects your tractor, and it is done with one word. It states that the motorized land conveyence must be used SOLELY to service your property. In other words, if you ever use your tractor to mow the neighbor's yard while he's on vacation, or push back his snowbanks in the winter, you are forever precluded from coverage under your homeowners policy for that tractor. One word makes a big difference in coverage on the new policy)</font>
If I understand this paragraph correctly, once I "violate" the provision and do something with the tractor that isn't on my property, that all coverage on that tractor is null & void forever into the future?? Even if the loss is on my residence property??
   / Need Tractor Insurance Help #16
Junkman - you are correct, that is exactly how the policy reads and is to be interpreted according to the analysis I've seen to the changes in the new edition. Many can't believe that this language was created this way since it is such a dramatic change. At this point, I am not aware if it has been litigated and interpreted by the courts, but I could be wrong about that. Is that crazy or what? I am actually in the process of changing my own insurace because my carrier (not my employer) is switching to the 2000 policy.
   / Need Tractor Insurance Help #17
This would effectively eliminate my tractor from coverage because my "driveway" crosses a section of discontinued town road at one corner of the property. There is no other way to the property, but half of that "road" belongs to the neighbor on the other side. I have an easement by prescription across that piece, but I don't own it, however I do maintain it. When it snows, I have to plow it or I can't get to my home. Just like an insurance company to give you coverage in paragraph 1,2, & 3, and then take is away in paragraph 18!!!!! I now have to get out my policy and start to read.... /forums/images/graemlins/frown.gif
   / Need Tractor Insurance Help #18
The policies can be difficult to work with sometimes. That was why I was trying to give some basic general information in my long post. Ultimately, if you're not sure where you stand, it is best to look at your policy and consult your agent, as Briarwood recommended originally. They are there to help you with these kinds of things and most do a good job. Sorry to create work for you Junkman, but better to know and research now rather than after you receive a denial letter for your claim. I would recommend that anyone concerned or confused contact their agent to be sure.
   / Need Tractor Insurance Help #19
Just read my renewal policy that came in the mail this week.... it is only a declaration page showing the coverage and cost. Guess that the insurance company doesn't issue a new policy upon renewal, but just a new declaration page. As usual, I don't know exactly where the little woman put the actual policy, but I will check on Monday. Did learn that my truck insurance is $450 for the year.... that works out to about $4.50 per mile, because I don't ever drive it anywhere. I just have it to plow the 1/2 mile road into the house.... and I doubt that I ever put more than a 100 miles on it a year... bought it used in 1982 with 26000 miles on it then and now it has just a tad over 29000 miles...
2016 Husqvarna YTA22V46 46in Riding Mower (A56859)
2016 Husqvarna...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
1997 Ford E-250 Cargo Van (A56858)
1997 Ford E-250...
2014 REITNOUER MAXIMISER 48' FLATBED TRAILER (A58018)
2014 REITNOUER...
2019 FORD F-350 SUPER DUTY SERVICE TRUCK (A58214)
2019 FORD F-350...
2014 Bolens 11A-020W765 20in Push Mower (A55973)
2014 Bolens...
