Loader need to know what kind of loader control valve to buy for jd 1050
   / need to know what kind of loader control valve to buy for jd 1050 #1
dtjones777
camden, ar.
89 JD 1050
Looking for a used control valve for 89 jd loader, or what kind do i buy for it ?
   / need to know what kind of loader control valve to buy for jd 1050 #2
:welcome: to the forum.
Looking up the 1050 utility in jdparts (you can too, and it is free registration), there are three SCV valves used (Two Cessna and one Dukes).
That may be the help you need to find a valve for your loader.
But is this the 1050 utility?
Or is this a 1050C or 1050J ?
Need more info from you
   / need to know what kind of loader control valve to buy for jd 1050 #3
Here are two loader valves.
First valve has float and regen.
Surplus Center - 2 SPOOL COMPACT 10 GPM JOYSTICK CONTROL VALVE
This valve has float.
Surplus Center - 2 SPOOL 25 GPM JOYSTICK LOADER CONTROL VALVE
   / need to know what kind of loader control valve to buy for jd 1050 #4
Spool valve needs to be open-center type.
   / need to know what kind of loader control valve to buy for jd 1050 #5
2022 Ligchine Spiderscreed Concrete Screed (A59228)
2022 Ligchine...
2016 F-250 4X4 (A56438)
2016 F-250 4X4...
Schulte XH1500 Series 4 Pull-Behind Batwing Rotary Brush Cutter Tractor Attachment (A59228)
Schulte XH1500...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2011 DOOSAN G25KW GENERATOR (A55745)
2011 DOOSAN G25KW...
Tandem Axle Rear Trailer Frame (A55851)
Tandem Axle Rear...
