Need to know what kind of Front axel fluid for YM336D
   / Need to know what kind of Front axel fluid for YM336D #1
mikereid
Jackson, GA
Yanmar YM1700
I have searched around the site. I need to know what fluid to put in the front axel of the 336D.
Thanks, Mike
   / Need to know what kind of Front axel fluid for YM336D #2
Not sure about your tractor but my 186D takes 90wt. gear oil in the front axel.
   / Need to know what kind of Front axel fluid for YM336D #3
According to the service manual it takes 7.4 qts of 90WT.
Steve
Wow - thats alot of lube
   / Need to know what kind of Front axel fluid for YM336D #5
Yes it is.
My tractor came to me so full it spewed all over when I took the dipstick/plug out and I drained about 3 qts out so maybe use the dipstick as the guide don't know what it holds for sure but that gets you started?
Steve
   / Need to know what kind of Front axel fluid for YM336D #6
Wow....that is a lot of lube. My 186D takes 3.2 qts. I just changed the oil a few weeks ago. When you check the level.....don't screw in the dipstick. Should be at the full mark without being screwed in. Good luck.
   / Need to know what kind of Front axel fluid for YM336D #7
You cant trust anything any more although the manual says quarts I suspect it means pounds which is a lot less more like a pint in volume all lost in translation from Japanese is my guess?
Steve
The 336 was a us sold machine. I would think the manual should be correct.
   / Need to know what kind of Front axel fluid for YM336D #9
My 336 manual states 8.5 qts for front drive gear case
   / Need to know what kind of Front axel fluid for YM336D #10
I have a 336D and have changed the oil twice. I used a 80/90 wt. oil and it took about 2 gallons.
2006 International 7400 Dump Truck (A47477)
2006 International...
2017 Ford Explorer AWD SUV (A53424)
2017 Ford Explorer...
2012 JOHN DERE 310K BACKHOE (A51406)
2012 JOHN DERE...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A54607)
2019 INTERNATIONAL...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A53843)
HYDRAULIC THUMB...
Takeuchi Skid Steer (A49461)
Takeuchi Skid...
