Need to Identify U joint
/ Need to Identify U joint #1
Believer
I have a 278 Bush Hog mower and exploded the U joint and sprung tractor yoke. Dealer with parts manual pulled out a yoke but it didn't match what I had, so maybe pto shaft was replaced. I finally found a yoke at Tractor Supply but after 9 stops I can't find the U joint. Yoke I got is metric. My imperial (inch) measurements of the U joint: cap diameter is 1.06 and width across is 2.94. Is there an internet source that I take the dimensions to and get a joint? Thanks.
/ Need to Identify U joint #2
Baum Hydraulics
Look at pto section of catalog.
not user friendly, but exhaustive
/ Need to Identify U joint #3
Give me the Metric ID of the hole in your yoke and how wide across the outside of the yoke. What configuration is your tubing, egg shaped, triangular, square, rectangular or splined? The 1.060 don't work for me. Ken Sweet
27mm cap, 74.5mm across. Shaft is triangular. Thanks. gwb 687.15 is a number I found on a web site if that helps.
/ Need to Identify U joint #5
I have that U-Joint in stock, Call me if you need it. We are open Labor Day 8-5-CST. Ken Sweet
SINGLE STAINLESS STEEL SINK (A63745)
SINGLE STAINLESS...
2017 PETERBILT 579 DAYCAB (A63569)
2017 PETERBILT 579...
2018 Komatsu D61PX Crawler Tractor Dozer (A59228)
2018 Komatsu D61PX...
2024 Bobcat T740 Track Loader (A63109)
2024 Bobcat T740...
KMC / PHILLIPS 3003A - 30' ROTARY HARROW (A63290)
KMC / PHILLIPS...
2022 Husqvarna Z560L Zero Turn (A63116)
2022 Husqvarna...
